Big-Kev1
  • 6
Message 1 of 9
How can i get a wifi booster
Being a new customer I'm not sure how I can get a booster for the wifi. I had one previously with sky as the signal at the far end of the house us not great.
Any help is appreciated.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 2 of 9
Re: How can i get a wifi booster
Virgin offer Wifi pods that are only free to customers on the Ultimate Oomph or Gig1 bundles.
Otherwise they cost a non financially viable £5 per month.
  • 6.45K
  • 1.01K
  • 1.59K
Message 3 of 9
If you still have your Sky booster try using that. You might have to reset it and use the Virgin SSID  and password
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 4 of 9
Sky boosters will only extend the 2.4Ghz band on non-Sky Broadband routers.
And most of the time you can’t connect to it as it looks for a Sky Router specifically to work.
ahrbee
  • 247
  • 11
  • 44
Superfast
Message 5 of 9
I suppose the simple answer is Amazon. I have used a TP-Link AC1750 range extender for several years and it has helped boost the wifi in rooms further from the router (an old VM Hub 2). This is not a recommendation. I am just relating my experience. There are lots of range extenders on the market, some apparently better for dealing with individual situations than others. Maybe the experts here can help point in a useful direction.
Very recently, my wife has had an issue after an update of her Samsung mobile which has not affected my Apple mobile. Her mobile occasionally and unaccountably loses wifi at distances from the router where previously it had been fine. I am not sure why this is happening. I have reconnected the range extender to the router but it has not solved the problem.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 6 of 9
Extenders only extend an already poor signal further.
Big-Kev1
  • 6
Message 7 of 9
Thanks all. I'm on oomph so I see what they are offering.
Cheers
ahrbee
  • 247
  • 11
  • 44
Superfast
Message 8 of 9
Apologies. In my ignorance, I assumed booster meant extender.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 9 of 9
@svhpaul wrote:
Sky boosters will only extend the 2.4Ghz band on non-Sky Broadband routers. And most of the time you can’t connect to it as it looks for a Sky Router specifically to work.
Thanks for copying my post 🙄
