How can I order some of the mesh pods for home?
NewKOTB
How can I order some of the pods for home?
I’m a new volt customers with the wifi max element added, I’ve got a temp cable run by your install team to allow for my printers/ pc's etc to get online. I need at least one pod to locate my hub in the actual room the incoming box is installed and remove temp cable to allow for RJ45 connection from pod to my none wifi enable devices in the home office.
Any help would be appreciated.
TIA
1 REPLY 1
Tom_W1
Hi @NewKOTB thanks for your post here in the Community although we're sorry to hear of the concerns you've raised here.
Please allow me to send you a PM so I can look into this further for you and order a WiFi Pod where possible.
Kindly expect the PM to arrive shortly and respond directly when you can!
Many thanks
Tom_W
