  • 9
Message 1 of 11
Home network has problems
I get this message but no information as to what the issues are. I have checked service status - there is apparently a local TV issue and run broadband test which identified a “technical” problem & sent a signal to fix. It says fixed on the VM site but network diagnostics for Hub still says problems on WiFi connection.
My Samsung TV is right next to the hub & when I try to update firmware I get an error message that my internet is too unstable so the update won’t run.
Telephony also has an issue. The phone works but I rarely use it due to much interference- constant buzz on the line - I think the error here (from what I read) is linked to my connection being an original Telewest box which is what is in my street.
The information I have suggests a problem but no guidance as to what it is or how to fix it ...
  • 11.65K
  • 899
  • 1.49K
Message 2 of 11
Re: Home network has problems
Then
Can you please
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.48K
  • 1.4K
  • 3.11K
Message 3 of 11
Contact support and raise the issue with them
  • 9
Message 4 of 11
Tags (1)
  • 24.48K
  • 1.4K
  • 3.11K
Message 5 of 11
There’s nothing wrong with that BQM. It shows no signs of dropped connections.
  • 9
Message 6 of 11
12030000000.236256 qam9
22110000000.237256 qam10
3219000000037256 qam11
4227000000-0.236256 qam12
5235000000-0.736256 qam13
6243000000-1.236256 qam14
7251000000-1.236256 qam15
82590000000.237256 qam16
92670000001.537256 qam17
10275000000237256 qam18
112830000002.437256 qam19
122910000002.537256 qam20
132990000002.737256 qam21
143070000002.737256 qam22
153150000002.737256 qam23
163230000002.937256 qam24
17331000000337256 qam25
183390000003.437256 qam26
193470000003.537256 qam27
20355000000337256 qam28
213630000001.937256 qam29
22371000000137256 qam30
233790000001.237256 qam31
243870000001.537256 qam32
1Locked36.6250
2Locked36.6440
3Locked37.3220
4Locked36.6300
5Locked36.6410
6Locked36.6680
7Locked36.3740
8Locked36.6560
9Locked37.390
10Locked37.3260
11Locked37.6260
12Locked37.3230
13Locked37.6140
14Locked37.6200
15Locked37.3230
16Locked37.6350
17Locked37.6240
18Locked37.3460
19Locked37.6220
20Locked37.6220
21Locked37.6120
22Locked37.6140
23Locked37.3250
24Locked37.640
  • 9
Message 7 of 11
14620000046.8512064 qam3
25370000047512064 qam2
33940000046.5512064 qam4
46030000047.5512064 qam1
3ATDMA0000
4ATDMA0000
  • 9
Message 8 of 11
24/10/2020 20:14:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 18:49:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 04:36:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 03:16:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 02:25:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/10/2020 14:46:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 05:00:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 02:46:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 03:34:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/10/2020 16:20:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 16:04:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 09:19:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 09:19:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 09:19:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 08:26:59criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 08:22:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 08:22:8criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 08:22:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 08:22:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 17.3K
  • 1.82K
  • 3K
Message 9 of 11
Hub data shows nothing obviously wrong suggesting any issues may be wifi related. What issues are you having on any devices connected by wifi and then on ethernet cables
Have you tried connecting the Samsung TV to the Hub by ethernet cable and see if that connects it to the internet and allows the updates? Mine is right next to my router but I still use a short Cat6 cable to connect it - much more reliable way to connect.
Re. the phone - are you using an old landline or the new phone connection directly to the Hub?
  • 9
Message 10 of 11
I think you’re right - there are 2 Ethernet ports on the hub so one has my Tado & currently the other an XBox but I will swap the XBox for the TV & see if that makes any difference.
i have a netgear powerline to get WiFi upstairs - I was sent out a VM booster but my printer wouldn’t connect & WiFi was poor so I plugged the Netgear back in again. I have Ethernet cable from booster to my laptop for home working but no longer get WiFi signal upstairs - big old house thick walls etc ...
phone is via old landline I believe.
