  • 98
  • 5
Up to speed
Message 1 of 8
Home WiFi Network Has a Few Problems
Been an odd few days, couple or so random drops of the connection, min latency creeping up, hub power levels especially on the upstream all over, they were about 3.5db but re settled back to about 4.3db.
Now running a diagnostic on the hub 3, it says I have a few WiFi home network problems. Considering I’m about 1 metre from the hub, I have noticed a slightly longer issue of loading stuff up. The hub has been on 23 days without a reboot.
How often should you reboot it? my previous ISP, I never rebooted the router for most of the year.
——————————————— My Broadband Ping - Virgin 200mb Connection
  • 11.99K
  • 934
  • 1.53K
Message 2 of 8
Re: Home WiFi Network Has a Few Problems
I reboot every week, others never bother.
Which Hub do you have ?
What is your contracted speed ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 98
  • 5
Up to speed
Message 3 of 8
Hub 3 & M200 package internet & phone only.
Can’t check service status as it seems virgin is working on the website.
  • 17.48K
  • 1.84K
  • 3.04K
Message 4 of 8
Service status website was down for me too yesterday but back up now. In any case, there is also a Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level (that may not be listed on the Area Status web page which usually covers >1000’s of customers) - that may give you more info, but even that wont cover problems affecting just a few customers
  • 98
  • 5
Up to speed
Message 5 of 8
Something not right here, every day I’m getting post RS errors on the line, a load more in the past 24 hrs and this is since the outage yesterday in a large area for a lot or people. My power levels look ok..what do I do? Speeds usually stick around 170-190 down 20 up
1331000000440256 qam25
22030000004.440256 qam9
32110000004.140256 qam10
4219000000440256 qam11
52270000003.740256 qam12
62350000003.440256 qam13
7243000000340256 qam14
82510000003.240256 qam15
92590000003.440256 qam16
102670000003.240256 qam17
112750000003.240256 qam18
122830000003.540256 qam19
132910000003.740256 qam20
14299000000440256 qam21
15307000000440256 qam22
16315000000440256 qam23
173230000003.940256 qam24
18339000000440256 qam26
19347000000440256 qam27
203550000003.740256 qam28
213630000003.740256 qam29
223710000003.540256 qam30
233790000003.540256 qam31
243870000003.540256 qam32
1Locked40.3612
2Locked40.347202
3Locked40.366313
4Locked40.338223
5Locked40.955250
6Locked40.959281
7Locked40.328276
8Locked40.342281
9Locked40.955177
10Locked40.352268
11Locked40.946253
12Locked40.942288
13Locked40.962205
14Locked40.347222
15Locked40.944364
16Locked40.340362
17Locked40.950275
18Locked40.346232
19Locked40.942283
20Locked40.947254
21Locked40.350337
22Locked40.950189
23Locked40.947333
24Locked40.371214
  • 98
  • 5
Up to speed
Message 6 of 8
1603000004.225512064 qam9
2394000004.025512032 qam12
3462000004.075512064 qam11
4537000004.225512064 qam10
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
gvca69834ncxv9873254k;fg87dsf
SFID672
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID671
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 98
  • 5
Up to speed
Message 7 of 8
29/10/2020 09:29:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 22:45:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 17:17:57noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 17:17:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 16:17:57noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 16:17:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 15:47:56noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 15:47:56ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 15:27:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:11:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:00:13criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:00:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 03:00:3criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:58:27criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:57:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:48:15criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:46:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:44:8criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:43:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:40:30criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 1.37K
  • 73
  • 140
Message 8 of 8
Good afternoon @Nigel1971
I have checked the account and there is still some working going on in the area.
I can assure you that we are working as hard as possible to get this resolved.
Kind regards,
Zak_M
