on 15-01-2023 16:54
I recently got a Hive central heating thermostat but the Hive Hub will not connect to my virgin router. It is connected via an Ethernet cable but the Hive Hub constantly flashes green which means it isn’t connected. I read a post saying I need to split the 5GHZ and 2.4GHZ networks, which I have done. But if I look at the settings page of my router the Hive Hub does not even show up on the list of connected Ethernet devices so I guess it isn’t being recognised or is blocked.
Hive said to me that perhaps the virgin router is blocking it and that I may need to “remove some blocks or shields” on my virgin router.
any advice would be helpful.
thanks
on 15-01-2023 16:56
If you are plugged in via Ethernet there is no 'blocking' that takes place.
15-01-2023 17:18 - edited 15-01-2023 17:43
@jameszuurbier wrote:I recently got a Hive central heating thermostat but the Hive Hub will not connect to my virgin router. <snip>
Which VM hub version are you using?
If you have a VM Hub 3, look where the ethernet cable from the Hive plugs into the VM hub. Is there a link light showing next to the ethernet plug? (Don't think the Hub 4 and 5 have any such lights).
Have you tried a different ethernet cable?
If you do a search on the word Hive in this forum, there is no shortage of past topics about Hive connection issues.
on 15-01-2023 17:58
Thanks - my Virgin router is a 3.0
Yes there is a light showing next to the Ethernet socket on the virgin router. So it seems it is being recognised by the router?
on 15-01-2023 18:26
The LED on the socket on the hub should flash to show data is being passed.
