on 28-04-2023 10:08
Anyone else is having issues connecting to sites that use the Highwinds CDN such as code.jquery.com that a variety of sites use such as https://bidb.uk/ and https://login.timesheetportal.com/ ? It just times out, the server is pingable. The content loads through a VPN.
Tracing route to code.jquery.com [69.16.175.42]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.254
2 10 ms 9 ms 10 ms 10.53.39.165
3 12 ms 12 ms 11 ms host-62-252-65.85.not-set-yet.virginmedia.net.65.252.62.in-addr.arpa [62.252.65.85]
4 * * * Request timed out.
5 21 ms 21 ms 23 ms tcma-ic-2-ae9-0.network.virginmedia.net [62.253.174.178]
6 31 ms 32 ms 21 ms host-62-252-5.73.not-set-yet.virginmedia.net.5.252.62.in-addr.arpa [62.252.5.73]
7 * * * Request timed out.
8 18 ms 18 ms 16 ms tlb.hwcdn.net [69.16.175.42]
Trace complete.
on 28-04-2023 13:53
Yes! Identical for me.
on 28-04-2023 13:54
Hello! I'm having absolutely exactly the same problem as you. Currently it is Friday, the 28th of April at 1:51 pm UK time.
I find that code.jquery.com just cannot be reached at all when on Virgin media. It was driving me mad until I saw your post 4 hours ago... FYI this stops things like dakboard.com boards from working (i.e. as is in my case, and any other sites which use CDNs for jQuery before they load).
on 28-04-2023 14:02
Same!
➜ ~ ping code.jquery.com
PING code.jquery.com (69.16.175.10): 56 data bytes
64 bytes from 69.16.175.10: icmp_seq=0 ttl=55 time=24.169 ms
➜ ~ curl http://code.jquery.com/
hangs forever
on 28-04-2023 14:07
I've just ran this and found it dead:
curl -v https://code.jquery.com
* Trying 69.16.175.42:443...
* Trying 2001:4de0:ac18::1:a:2a:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:2a: Network is unreachable
* Trying 2001:4de0:ac18::1:a:2b:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:2b: Network is unreachable
* Trying 2001:4de0:ac18::1:a:3b:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:3b: Network is unreachable
* Trying 2001:4de0:ac18::1:a:1a:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:1a: Network is unreachable
* Trying 2001:4de0:ac18::1:a:1b:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:1b: Network is unreachable
* Trying 2001:4de0:ac18::1:a:3a:443...
* Immediate connect fail for 2001:4de0:ac18::1:a:3a: Network is unreachable
on 28-04-2023 15:35
I'm glad its not just me. It works fine on a vpn and works fine from a server from work so I guess its a issue to virginmedia. I found it stopped working yesterday.
As said above it stops other sites from working correctly.which uses jquery to function when they don't host the files internally.
on 28-04-2023 15:44
bidb.uk been fine here for days/weeks and today.....Sometimes the detail pane of 4G/5G can have a spinning wheel. It mostly does this on the vodafone section.
on 28-04-2023 15:59
https://bidb.uk/ All ok here, I am NOT using Virgin D.N.S.
on 28-04-2023 16:05
Im not using virgin dns either. I have tried cloudfare, google and quad 9 dns servers It also depends on whether your browser has cached the scripts it getting from code,jquery.com . If all is OK you should be able to visit the site http://code.jquery.com too.
It could also be region specific with routing issues. I am from Teesside.
28-04-2023 16:12 - edited 28-04-2023 16:14
http://code.jquery.com took a long time to resolve to: https://releases.jquery.com/
WEST YORKS
