  • 9
Message 1 of 15
High post RS errors and frequent instability
Hey there,
Currently I'm at my wits end with this problem -- I'm experiencing frequent disconnections and I believe it's due to a high amount of post RS errors.
Since my line installation back in May, I've had frequent errors and have never been able to consider my line as "stable". It's fine until it isn't, then there's a whole ~10 seconds of network lag / disconnection.
I had an engineer out who turned my dBmV levels up as they were low, they now look like this:
12510000007.340256 qam15
2203000000840256 qam9
32110000007.940256 qam10
42190000007.540256 qam11
5227000000740256 qam12
62350000006.540256 qam13
7243000000740256 qam14
82590000007.340256 qam16
92670000007.340256 qam17
102750000007.140256 qam18
11283000000740256 qam19
12291000000740256 qam20
13299000000740256 qam21
14307000000740256 qam22
153150000006.940256 qam23
163230000006.640256 qam24
173310000006.340256 qam25
183710000006.440256 qam26
193790000006.540256 qam27
203870000006.840256 qam28
213950000006.940256 qam29
22403000000740256 qam30
23411000000740256 qam31
24419000000740256 qam32
Since then, the issue got far less frequent, although it still happens. My equipment is as follows:
Super Hub 3 running in modem mode, connected to a Draytek Vigor 2925n. I'm directly connected to the Draytek via an ethernet cable & speed test at my expected speed.
My post RS errors are as follows:
1Locked40.33983032179
2Locked40.35295139045
3Locked40.35031936869
4Locked40.34772635908
5Locked40.34568135714
6Locked40.34348835168
7Locked40.34185332962
8Locked40.33848931108
9Locked40.93690629987
10Locked40.93576829921
11Locked40.33552029729
12Locked40.33495229946
13Locked40.33510829921
14Locked40.33439929315
15Locked40.93375830051
16Locked40.33304028829
17Locked40.33293527719
18Locked40.32790322151
19Locked40.32693120266
20Locked40.92575719178
21Locked40.92418919710
22Locked40.92341318511
23Locked40.92249417947
24Locked40.92163516582
13260000036.3512064 qam3
22580000036.3512064 qam4
33940000036.3512064 qam2
44620000037.8512064 qam1
2ATDMA0030
3ATDMA0020
4ATDMA0000
Think Broadband Monitor
Clearly something is wrong there. Can anyone help me here? If not it'll be early cancellation and off to BT, rather a fifth of the speed over this diabolical stability issue.
Thanks guys,
Josh
  • 24.99K
  • 1.44K
  • 3.18K
Message 2 of 15
Re: High post RS errors and frequent instability
Post the upstream logs as well and a live BQM share link rather than a static image.
When was the hub last rebooted?
  • 9
Message 3 of 15
Hey Gary,
I've updated my post with those for you, appreciate the response.
Hub was rebooted yesterday AM, further disconnections today.
  • 9
Message 4 of 15
Rebooted again yesterday @ ~4PM
1Locked40.325032121
2Locked40.327332256
3Locked40.923372107
4Locked40.323761949
5Locked40.322251909
6Locked40.322031919
7Locked40.920511815
8Locked40.319791737
9Locked40.919321797
10Locked40.319231610
11Locked40.318671724
12Locked40.318511614
13Locked40.318781717
14Locked40.918361669
15Locked40.918301602
16Locked40.317331670
17Locked40.318021554
18Locked40.916021140
19Locked40.315321056
20Locked40.314071058
21Locked40.913181186
22Locked40.312841157
23Locked40.912871064
24Locked40.31163956
Todays GraphTodays Graph
  • 24.99K
  • 1.44K
  • 3.18K
Message 5 of 15
1Locked40.325032121
2Locked40.327332256
3Locked40.923372107
4Locked40.323761949
5Locked40.322251909
6Locked40.322031919
7Locked40.920511815
8Locked40.319791737
9Locked40.919321797
24Locked40.31163956
Have you checked all connections are tight at the hub and wall box?
  • 9
Message 6 of 15
I have personally checked the connections / tightness of screws and such, and I have had an engineer out to attempt to resolve this in the past. I'd have expected they would be more well versed in how tight things should be and would have verified this too right?
  • 24.99K
  • 1.44K
  • 3.18K
Message 7 of 15
Have you setup a BQM graph?
  • 9
Message 8 of 15
  • 24.99K
  • 1.44K
  • 3.18K
Message 9 of 15
Yeah
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b9437a8e10c4d8cf3f7618dc7ff94895f1...
Here we are
Thanks. It looks to be a line issue then. It would be wise to get an engineer booked either by calling in or waiting for a forum mod to reply here which could take a few days.
  • 9
Message 10 of 15
Gary, I just want to say thank you so much for your time. it's people like you that act as a bastion of hope that people can be good.
You have been absolutely critical in helping me diagnose this issue, and conform the the expected etiquette of these forums. Thank you for everything.
I'll likely wait for a moderator to comment here, maybe they can provide context to the problem as the previous engineer didn't see anything wrong with my line even when the dBmV levels were close to 0. I don't want to be doing their job for them ay!
Thanks again.
