Hello,
Here is the live graph:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3bd1a830cc7c7fa5d4737b0f7f948f839e6a53b5
Router status:
Cable Modem Status
Item Status Comments
426750000
Locked
Ranged Upstream Channel (Hz)
46199976
Locked
Provisioning State
Online
1 426750000 5.9 40 256 qam 37
2 258750000 6.8 40 256 qam 16
3 266750000 6.8 40 256 qam 17
4 274750000 6.6 40 256 qam 18
5 282750000 6.9 40 256 qam 19
6 290750000 6.8 40 256 qam 20
7 298750000 6.8 40 256 qam 21
8 306750000 6.4 40 256 qam 22
9 314750000 6.3 40 256 qam 23
10 322750000 6.5 40 256 qam 24
11 330750000 6.5 40 256 qam 25
12 338750000 6.3 40 256 qam 26
13 346750000 6.3 40 256 qam 27
14 354750000 6.3 40 256 qam 28
15 362750000 6.4 40 256 qam 29
16 370750000 6 40 256 qam 30
17 378750000 5.9 40 256 qam 31
18 386750000 5.6 40 256 qam 32
19 394750000 5.6 40 256 qam 33
20 402750000 5.6 40 256 qam 34
21 410750000 5.9 40 256 qam 35
22 418750000 6 40 256 qam 36
23 434750000 5.8 40 256 qam 38
24 442750000 5.3 40 256 qam 39
1 Locked 40.9 11 0
2 Locked 40.9 15 0
3 Locked 40.9 6 0
4 Locked 40.3 11 0
5 Locked 40.9 9 0
6 Locked 40.9 7 0
7 Locked 40.9 3 0
8 Locked 40.9 12 0
9 Locked 40.9 6 0
10 Locked 40.9 8 0
11 Locked 40.9 7 0
12 Locked 40.3 9 0
13 Locked 40.3 11 0
14 Locked 40.9 7 0
15 Locked 40.9 6 0
16 Locked 40.9 7 0
17 Locked 40.9 12 0
18 Locked 40.3 8 0
19 Locked 40.9 10 0
20 Locked 40.3 6 0
21 Locked 40.9 5 0
22 Locked 40.9 6 0
1 46199976 40.5 5120 64 qam 3
2 39400009 40.5 5120 64 qam 4
3 53700000 40.5 5120 64 qam 2
4 60300000 40.5 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;fg87dsfd;kfoA,.iyewrkldJ
SFID 1326
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 1325
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
24/05/2022 15:27:51 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2022 10:28:48 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:28:50 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:25:26 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:24:59 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:24:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:24:32 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:23:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:23:2 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:45 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:45 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:42 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2022 19:22:39 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 05:44:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 05:44:41 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 05:44:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 05:44:1 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 05:43:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
