on 04-10-2023 11:28
We're currently getting regular internet dropouts, with connection speeds of 5-10mbps instead of our usual 250mbps. When I run the Service Check on the VM website, it says that nothing is wrong. However, looking at the Hub 3 status, there seem to be a few oddities. All downstream channels seem to have a power level between 9.9 and 12.4 dBmV - considerably higher that Seth's recommended levels. In addition, 12 of the 14 channels have a SNR below 34 dB and a fair few post RS errors. The network logs have many RCS Partial Service warnings and Lost MDD Timeouts.
Anyone have any suggestions on the best way to get the issues resolved, please?
Martin
1 | 139000000 | 12.3 | 27 | 256 qam | 1 |
2 | 147000000 | 12.3 | 32 | 256 qam | 2 |
3 | 155000000 | 11.6 | 30 | 256 qam | 3 |
4 | 163000000 | 11.4 | 30 | 256 qam | 4 |
5 | 251000000 | 10 | 29 | 256 qam | 15 |
6 | 259000000 | 10.4 | 29 | 256 qam | 16 |
7 | 267000000 | 10.6 | 33 | 256 qam | 17 |
8 | 275000000 | 10.5 | 35 | 256 qam | 18 |
9 | 283000000 | 10.5 | 33 | 256 qam | 19 |
10 | 291000000 | 10.5 | 31 | 256 qam | 20 |
11 | 299000000 | 10.3 | 32 | 256 qam | 21 |
12 | 307000000 | 10 | 35 | 256 qam | 22 |
13 | 315000000 | 10 | 33 | 256 qam | 23 |
14 | 323000000 | 9.8 | 25 | 256 qam | 0 |
1 | Locked | 27.4 | 9462751 | 109746 |
2 | Locked | 32.3 | 845826 | 0 |
3 | Locked | 30.8 | 125881 | 0 |
4 | Locked | 30.2 | 179220 | 0 |
5 | Locked | 29.2 | 1717594 | 0 |
6 | Locked | 29.8 | 634065 | 0 |
7 | Locked | 33 | 33 | 0 |
8 | Locked | 35.7 | 5 | 0 |
9 | Locked | 33.4 | 14 | 0 |
10 | Locked | 32.2 | 1323 | 0 |
11 | Locked | 32.9 | 137 | 0 |
12 | Locked | 35.5 | 5 | 0 |
13 | Locked | 33.9 | 36 | 0 |
14 | Locked | 25 | 318 | 8457831 |
04-10-2023 13:59 - edited 04-10-2023 14:03
That is one dreadful connection ! VM will need to look at it but it will need a Tech visit. A VM Person ought to respond here soon.
In the meantime...
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and any upstream T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
on 04-10-2023 14:08
Hey DocMN, thank you for reaching out and I am so sorry to hear about this.
I am going to send you a PM so we can look into this for you.
Please look out for my PM. Cheers
Matt - Forum Team
New around here?
on 04-10-2023 15:24
Hey DocMN, thank you for reaching out again and I am glad we have managed to get this resolved for you.
Please do let us know how the visit goes. Cheers
Matt - Forum Team
New around here?
