on 27-12-2022 12:45
Hi I am with VM for over a year now and I am getting constant disconnections on my 1Gb broadband - both wired and wireless. Its getting to the point where playing online games is impossible not to mention that this poor service negatively affects our working from home as myself, my son and my wife getting regular disconnections during the google meets, teams and so on.
Hub data below - I will also paste BQM graphs as these are showing regular packet losses. Can anyone look at these and let me know if there is anything of concern from the data and graphs pasted?
Cable Modem Status Item Status Comments Channel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 29-12-2022 08:43
And finally here is the latest BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a792ab64105012155bbbd05bf854bb1e8f630b75-29-12-2022
on 31-12-2022 10:15
on 31-12-2022 10:41
Hi @buchosmambo
I am sorry to hear of the broadband issues. You do need a tech visit as both the upstream and downstream power levels are out of spec.
I'll send you a PM to book this in
Best,
on 31-12-2022 15:02
Hi @buchosmambo
Thanks for joining me on PM and providing me the details to book in the tech visit for the downstream/upstream issues. You'll see the appointment within a few hours in your online account - virg.in/myVM
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment
Let us know how the visit goes or if you ever need anything, please do pop back to our community forums 🙂
on 31-12-2022 15:30
Hi buchosmambo thanks for the message but we don't need to PM currently 🙂
Power levels should be between -6 and +10,
To find them;
Shows you there 🙂
Best,
on 31-12-2022 16:06
Thanks John.
on 09-01-2023 21:57
So unfortunatelly 5 days after the Engineer visit things are much worse than previously.
Please see live BQM below
https://www.thinkbroadband.com/broadband/monitoring/quality/share/52b6e6666a79b5ca6aaaf92c0c1ebffbcebdd1f3
Engineer installed attenuator, and new socket all together which brought the Power Levels to within the range and things were ok for approx one day but Im now getting larger packet losses, more frequent high pings and overal the connection seems awful - it still affect wired connection to my ps4 and ps5 where once every 30minutes online gaming is impossible for approx 20s. We lost connection for approx 3h on Saturday Morning. No faults reported in our area.
Wirelles is to say at least horrible... I will connect to whatsap video call and it takes approx 30s for my Mum to be able to see me on the cam and thats standing next to the hub.
Im getting fed up wit this now... Paying for something that doesnt serve its purpose....
on 11-01-2023 09:08
Update for VM Support Team.
On 4th of Jan - VM Engineer installs attenuator to reduce noise on the line - Power Levels back to normal graph below:
On the 5th of Jan internet works smoothly and like it should. Graph below:
6th of Jan - as above, everything works smooth and fine. Wife started reporting some issues with WhatsApp vide calls where her Mum wouldnt see her on video for 1st 30s or so. Strange as she usually does that in the Kitchen next to WIFI POD. I didnt notice anything strange.... Graph below:
Saturday the 7th of Jan - I didnt even know we lost the connection for few hours. I only realized it on Sunday I noticed that connection started to behave like in the old days...
Sunday 8th of Jan - line started acting like in old days, regular drop outs, connection losses at very regular time intervals (in my view every half hour)
Mon 9th of Jan - I am literally getting bad feedback from my work colleagues and Manager for how bad my line is. Regular drops, at half hour intervals. Negative effect on both wifi and wired connection to consoles.
Tues 10th of Jan - connection still bad to the point where my son is unable to work from home - he had few important calls so we decided to reset the hub and at the same time switch off WIFI Pod, separate two networks to separate 2.4 and separate 5 Ghz by adding 5 on the end of 5Ghz network. Smart WIFI disabled and channels on both networks set to Manual (Chanel 6 for 2,4 and 48 for 5 GHz) Whatever it was - something made a difference as no more drops - graph below:
Today we are getting drops once again - continuation of the graph below (red disconnection block took place yesterday at 10 AM)
I will paste the channels and power levels data in separate reply.
I would really appreciate the help from VM team - what could be the cause of this? I understand that WiFi can be flaky depending on property but for it to be happening also on wired connection seems like there is something wrong with the Hub. This forum is full of posts like mine where regular drops at frequent time intervals are taking place. I also dont mind investing in my own router with mesh system but I want to make sure the line performs like it should 1sy before I cash out few 100s of £s
on 11-01-2023 09:11
Cable Modem Status
5 | 443000000 | 2.900002 | 36.609653 | QAM256 | 5 |
1 | 411000000 | 1.700001 | 35.779911 | QAM256 | 1 |
2 | 419000000 | 2.099998 | 36.609653 | QAM256 | 2 |
3 | 427000000 | 2.400002 | 36.386890 | QAM256 | 3 |
4 | 435000000 | 2.500000 | 36.609653 | QAM256 | 4 |
6 | 451000000 | 3.500000 | 36.609653 | QAM256 | 6 |
7 | 459000000 | 3.400002 | 36.609653 | QAM256 | 7 |
8 | 467000000 | 3.700001 | 36.609653 | QAM256 | 8 |
9 | 475000000 | 3.500000 | 36.386890 | QAM256 | 9 |
10 | 483000000 | 3.900002 | 36.609653 | QAM256 | 10 |
11 | 491000000 | 4.099998 | 36.609653 | QAM256 | 11 |
12 | 499000000 | 4.300003 | 36.609653 | QAM256 | 12 |
13 | 507000000 | 4.099998 | 37.092701 | QAM256 | 13 |
14 | 515000000 | 4.199997 | 36.386890 | QAM256 | 14 |
15 | 523000000 | 4.199997 | 36.609653 | QAM256 | 15 |
16 | 531000000 | 4.599998 | 37.636276 | QAM256 | 16 |
17 | 539000000 | 4.900002 | 37.355988 | QAM256 | 17 |
18 | 547000000 | 4.900002 | 37.355988 | QAM256 | 18 |
19 | 555000000 | 4.900002 | 37.355988 | QAM256 | 19 |
20 | 563000000 | 4.800003 | 37.636276 | QAM256 | 20 |
21 | 571000000 | 4.900002 | 37.636276 | QAM256 | 21 |
22 | 579000000 | 4.699997 | 37.355988 | QAM256 | 22 |
23 | 587000000 | 4.900002 | 37.355988 | QAM256 | 23 |
24 | 595000000 | 4.599998 | 37.636276 | QAM256 | 24 |
25 | 603000000 | 4.800003 | 37.355988 | QAM256 | 25 |
26 | 611000000 | 4.300003 | 37.355988 | QAM256 | 26 |
27 | 619000000 | 4.199997 | 37.355988 | QAM256 | 27 |
28 | 627000000 | 3.700001 | 37.355988 | QAM256 | 28 |
29 | 635000000 | 3.599998 | 37.355988 | QAM256 | 29 |
30 | 643000000 | 3.200001 | 37.636276 | QAM256 | 30 |
31 | 651000000 | 3.000000 | 37.355988 | QAM256 | 31 |
5 | Locked | 36.609653 | 0 | 0 |
1 | Locked | 35.779911 | 1 | 0 |
2 | Locked | 36.609653 | 0 | 0 |
3 | Locked | 36.386890 | 0 | 0 |
4 | Locked | 36.609653 | 0 | 0 |
6 | Locked | 36.609653 | 0 | 0 |
7 | Locked | 36.609653 | 0 | 0 |
8 | Locked | 36.609653 | 0 | 0 |
9 | Locked | 36.386890 | 0 | 0 |
10 | Locked | 36.609653 | 0 | 0 |
11 | Locked | 36.609653 | 0 | 0 |
12 | Locked | 36.609653 | 0 | 0 |
13 | Locked | 37.092701 | 0 | 0 |
14 | Locked | 36.386890 | 0 | 0 |
15 | Locked | 36.609653 | 1 | 0 |
16 | Locked | 37.636276 | 0 | 0 |
17 | Locked | 37.355988 | 0 | 0 |
18 | Locked | 37.355988 | 0 | 0 |
19 | Locked | 37.355988 | 0 | 0 |
20 | Locked | 37.636276 | 0 | 0 |
21 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.355988 | 0 | 0 |
23 | Locked | 37.355988 | 0 | 0 |
24 | Locked | 37.636276 | 0 | 0 |
25 | Locked | 37.355988 | 0 | 0 |
26 | Locked | 37.355988 | 0 | 0 |
27 | Locked | 37.355988 | 0 | 0 |
28 | Locked | 37.355988 | 0 | 0 |
29 | Locked | 37.355988 | 0 | 0 |
30 | Locked | 37.636276 | 0 | 0 |
31 | Locked | 37.355988 | 0 | 0 |
on 11-01-2023 09:13
159 | 96 | 4K | 1880 | QAM4096 | 759 |
Channel ID Lock Status RxMER Data (dB) PLC Power (dBmV) (Active Profile) (Active Profile)
159 | Locked | 39 | -2.5 | 507834588 | 0 |
1 | 43100000 | 37.520599 | 5120 KSym/sec | 64QAM | 10 |
2 | 23600000 | 35.520599 | 5120 KSym/sec | 64QAM | 13 |
3 | 30100000 | 36.020599 | 5120 KSym/sec | 64QAM | 12 |
4 | 36600000 | 36.520599 | 5120 KSym/sec | 64QAM | 11 |
5 | 49600000 | 38.020599 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
14 | 10.0 | 32.5 | 2K | QAM8 |
14 | OFDMA | 200 | 53.9 | 0 | 0 |
