  • 5
Message 1 of 21
High Latency, Ping, and packet loss
Hi, I have constant drop outs of Wifi, and cabled LAN.
Sometimes it is ok, sometimes very poor, and sometimes no connection at all.
I have swithched off the hub 3.0, reset the hub, but makes no difference.
I have used ThinkBroadBand quality monitor to see the issues and timings.
Using Virgin Status check it states that there are no issues.
I wonder if the hub itself is starting to fail ? Esp. as it happens over WIFI and cable.
Any assistance would be really useful, thanks.
  • 3.51K
  • 567
  • 1.38K
Message 2 of 21
Re: High Latency, Ping, and packet loss
Go to Thinkbroadband, and you'll see a link under your BQM that says "share snapshot graph".  Click on that, then copy and paste the link here, and we'll be able to comment.  Don't post as an image - takes too long for these to be approved.
  • 5
Message 3 of 21
  • 3.51K
  • 567
  • 1.38K
Message 4 of 21
That's looking bad, but we'll need a 24 hour trace to have a good view.  Leave it running, repost when there's 24 hours of data.
  • 14.28K
  • 591
  • 1.37K
Message 5 of 21
@Tiggs0901 wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/45e11929a1053e9638a348f7eb6e986d34...
That don't look like a VM BQM check your IP VM will have a minimum 5ms + Latency .
  • 12
Message 6 of 21
Will do.
I have had weeks of this, but only just started the monitor.
  • 12
Message 7 of 21
Sorry, what do you mean ?
Of course it is VM
  • 14.28K
  • 591
  • 1.37K
Message 8 of 21
Docsis has a minimum Latency of 5+ms RTT your BQM does not show this.
run a tracert 80.249.99.164
  • 12
Message 9 of 21
Ah, I set it up on work laptop, so going through their server.
I have set up a new monitor directly using IP 165.225.81.30 so should be ok now. I will post a link to the new graph tomorrow.
  • 14.28K
  • 591
  • 1.37K
Message 10 of 21
That don't look like a VM IP.
