07-04-2022 18:59 - edited 07-04-2022 19:00
Not sure if anyone can help, certainly the helpdesk can't, all I've had for the last week to solve the issue are router restarts by the service desk. Issue I'm having is consistent latency issues and intermittent packet loss.
I feel completely at my witts end, so much so that I've raised an Offcom approval case to get the disconnection fees dropped so I can leave.
I'll post some logs below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7767b9be5d7cc683371e68d85fdc294d1150d271
on 14-04-2022 17:46
Hi Carley,
Using my own tp link router has made a marginal difference, peak times are indeed the worst. Anything from about 8am until 11.30pm is terable. I've just upgraded from the 200m to 350m to see if it helps. I'm thinking not tbh, the upgrade has just gone live around an hour ago. Today's stats below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e69b49b43788d6789e1ecfa8b2493b324fb8501d-14-04-2022
on 14-04-2022 18:27
14-04-2022 19:32 - edited 14-04-2022 19:36
Hi Alessandro,
Thanks for your suggestions. Yes routers not the issue I reverted back to the Virgin router as the helpdesk told me all my issues would be resolved, guess what? .... yup.
So seeing as it made zero difference, (which I was expecting) but as no further troubleshooting was going to take place until I did, I went ahead.
I have enabled the quality of service feature on the router but made no difference. The issue has to be down to over utilisation in my area. It's latacey spikes which is the killer, if I ping google or the BBC about every twelve pings it has a large ping jump. I also did a trace route and I'm getting the same intermittent spike when contacting the 4th hop, which happens to be a Virgin server.
on 15-04-2022 12:31
Yesterday's stats
As I thought a speed increase made zero diffrence.
16-04-2022 10:09 - edited 16-04-2022 10:11
Yesterday's stats:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d7a767905fb01222ddc62e989bfb2938d284a6fa-15-04-2022
This continues to be completely unacceptable, service desk are clueless, obviously folowing a script and if what you tell them deviates they reboot your router and ask you to phone back if the issue isn't resolved. There is no (or appears to be no) escalation route for issues like mine, and other users who are having the exact same issue. Looking on the forum this appears to be a common issue, and in most cases the resolve appears to be ignore the consumer in the hope the issue will miraculous resolve by itself, or the consumer needs to put up and shut up.
So where do I go from here?
On the plus side, I'm getting loads of badges
on 18-04-2022 10:25
I am sorry for any connection issues you've been experiencing Postal69,
Looking from our side there are no current issues showing, as you've mentioned using a 3rd party router we'd be unable to run through further diagnostics whilst this is the case.
If you're able to pop the hub back into router mode we'll be happy to go through further checks.
Alex_Rm
on 18-04-2022 10:44
Hi Alex,
Sounds like we're going back in a loop regarding the trouble shooting, if you go back through the post you will see that having the virgin router in router mode made zero difference. If this is going to be beneficial I will do it... Again. Its extremely time consuming and disruptive having to keep doing this. Could you tell me what tests you're hoping to complete? And if you have access to my issues log, could you check these haven't already been complete?
on 20-04-2022 10:55
Hi Postal69,
Thank you for reaching back out, we understand the frustration having to keep resetting things, our system will stop any diagnostic checks once it cannot see our Router and we advise it is a 3rd party Router, having checked again myself just now and cannot see any issues at all, please can you post your most recent BQM graph as we cannot see the ones previously posted.
Paul.
