Hi can anyone help, i have a firestick connected with a ethernet cable. But still seems to buffer, and is
sharonyoung1
Hi can anyone help, I have a firestick connected with a ethernet cable but still buffers, and is saying, it is connected with issues an needs update configuration. Eonder if it is something in settings. Any help appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Also go into the Apps section and clear the cache of apps you don't really use, or indeed uninstall unused apps all together.  You can always add them back again.  I would do this on my Firestick now and again.  It's also cabled, but i very rarely see any buffering.
3 REPLIES 3
Hi sharonyoung1
Firesticks can buffer if they are out of physical memory although it sounds like there is a firestick update that needs installing
Click the settings gear (cog wheel) at the far right side of your screen.
Scroll down and select the My Fire TV option
Then, click on About. Then  scroll down and select the Check for Updates or Install Update button.
If an update is available for your FireStick and it has already downloaded the update, you’ll see the Install Update button.
After clicking Install Update, the updates will start installing. Make sure not to turn off the power while updates are being installed. After a few minutes, FireStick will complete the update and reboot automatically.
(The latest version I have is Fire OS 6.2.9.7 (NS6297/4655)
Dave
The do's and don'ts.
Roger_Gooner
Have you run a speed test? Mine is 293.69Mbps.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
