fantasyvn
Help with the problem of my 5GHz channel
Could you pls help me? I am a Virgin Media broadband customer. I tried to call them but did not get to speak with anyone today, so I am posting it here.
On Monday night, there was a power surge in my local area.
Since then it seems there was a problem with my 5GHz channel. Devices would connect and then drop off. Right now I have to use the 2.4GHz signal.
Pls let me know which information I should provide here so that Virgin Media can help me.
Thank you
g0akc
  • 999
  • 92
  • 197
Well-informed
Re: Help with the problem of my 5GHz channel
Have you split the WiFi bands?
Can you login to the hub and check 5GHz is enabled?
Was there a power outage?
Try a factory reset if necessary - then split bands again if you want
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
fantasyvn
Hi, thank you for your kind reply. I was able to connect to Virgin Media on the phone and they gave me a solution. So for now, pls consider this thread is closed.
My sincere thanks,
Ayisha_B
  • 1.46K
  • 51
  • 139
Hi @fantasyvn,
Welcome to our Community Forums and thanks for posting.
I am glad to hear our team were able to offer a solution to get this fixed 🙂
Please don't hesitate to pop back if you have any further issues.
Take care!
Ayisha_B
