THEBOSWELLS
Message 1 of 5
Help with BQM
https://www.thinkbroadband.com/speedtest/1612663119625089055 Hi, can anyone help me understand what the results of my BQM mean?  I want to monitor our WiFi speeds as I’ve been really unhappy with our broadband since joint Virgin in July 2020.  It’s never seemed right to me, had lots of problems from the get go.
Tags (1)
JitteryPinger
  • 1.73K
  • 188
  • 342
Super solver
Message 2 of 5
Re: Help with BQM
You have only linked in speed test results, please post direct link to BQM
If I've helped please let me know 🙂 Matt
A 10+ Year Virgin Media veteran, been here through the Up's and the Down's and Down's....
Vodafone 5G EE BQM Hub 4 BQM Hub 3 BQM Hitron CGNV4 BQM TT BQM
Technical Support - AV & Networking - Customer Service - Finance - Culinary - Construction
THEBOSWELLS
Message 3 of 5
Re: Help with BQM
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/5c898ad6bdbaf1741084afbd49cbc...
hope the above link is ok? Not sure how to get a link for full history??
Tags (1)
cje85
  • 2.58K
  • 162
  • 675
Trouble shooter
Message 4 of 5
Re: Help with BQM
The link doesn't work but I think i've worked out what it should be
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5c898ad6bdbaf1741084afbd49cbcfdbdc...
If correct that's not particularly bad, especially compared to some BQMs that are being posted at the moment.
How are you testing the speeds, WiFi or wired?
From the BQM alone there doesn't seem to be any reason for such poor speeds.
conman33158
  • 726
  • 66
  • 95
Superfast
Message 5 of 5
Re: Help with BQM
How is your speed on a wired connection? Could be just the poor wireless that come with the Virgin hubs, in which case you would be better of with a third party router with better wireless capabilities. It also depends on your devices also, are they connected to 2.4Ghz which is very slow, 5Ghz would be faster but has a shorter distance/range.
