  • 59
Help poor internet wired and wireless
we are getting really poor internet keeps cutting out and losing WiFi randomly loses signal it’s happening on wired devices and WiFi super hub 3 I’m just about ready to switch to sky I know I’ll probably regret it but last 4 months have been worse ever and virgin media do not seem interested in fixing the issue just tells me I needed WiFi boosters which have made no difference at all on router status I’m getting lots of errors
21/10/2020 12:15:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 11:06:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 21:08:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 14:23:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 14:23:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 14:23:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 23:06:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 21:18:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 19:38:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/10/2020 18:46:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2020 13:33:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2020 04:13:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2020 01:03:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 13:47:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 13:03:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 02:00:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 01:03:42ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 00:26:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:01:5c:82
  • 59
Re: Help poor internet wired and wireless
1Locked38.917855486
2Locked38.916515417
3Locked38.916035372
4Locked38.616135393
5Locked38.615955398
6Locked38.617085471
7Locked38.917005530
8Locked38.916625494
9Locked38.616835410
10Locked38.916995505
11Locked38.616495368
12Locked38.916745567
13Locked38.917165437
14Locked38.617285489
15Locked38.619405456
16Locked38.619475427
17Locked38.918325488
18Locked38.620035599
19Locked38.918615479
20Locked38.918135376
21Locked38.917765482
22Locked38.617725365
23Locked38.617905413
24Locked38.919065503
  • 11.91K
  • 927
  • 1.53K
Can you post the first table from the Downstream data and both tables from the Upstream data please.
Mike Robinson
  • 59
First table from downstream
12030000005.938256 qam9
22110000005.938256 qam10
3219000000638256 qam11
4227000000638256 qam12
52350000005.938256 qam13
62430000005.938256 qam14
72510000005.538256 qam15
82590000005.638256 qam16
92670000005.838256 qam17
10275000000638256 qam18
112830000006.438256 qam19
122910000006.338256 qam20
13299000000638256 qam21
143070000005.838256 qam22
153150000005.638256 qam23
163230000005.838256 qam24
173310000005.938256 qam25
183710000005.938256 qam26
19379000000638256 qam27
203870000006.438256 qam28
213950000006.538256 qam29
22403000000738256 qam30
234110000007.438256 qam31
244190000007.538256 qam32
  • 59
Upstream tables
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1461999714.729512064 qam1
2326000004.579512064 qam3
3257999254.504512064 qam4
4394000334.654512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 2.6K
  • 158
  • 209
Moderator
Moderator
Hi deano1,
Thanks for posting.
Apologies for the delay getting back to you and that you've been experiencing problems with both your wired and wireless connection.
I've had a look at your services and can see that you did have prolonged signal issues which would have been causing some problems. It looks like these have gone back to a normal range since you posted, so I'm hoping you've noticed an improvement?
If you still need help with this, then please let me know.
Melissa
