Stevego
  • 37
  • 7
Message 1 of 7
Help on HUB 3 Levels - Dropping Connections
Hi Guys,
I am having problems since going from HUB 2 to HUB3.
Do these levels look to be OK - look very low to me!
Sorry some of the formatting seems to have gone awry....
Any help and advice would be appreciated.
Steve
14310000051512064 qam2
22360000051512064 qam9
33660000051512064 qam3
44960000051512064 qam1
53010000051512064 qam4
1138750000-4.238256 qam1
2146750000-4.238256 qam2
3154750000-4.238256 qam3
4162750000-4.238256 qam4
5170750000-4.438256 qam5
6178750000-4.538256 qam6
7186750000-4.538256 qam7
8194750000-4.438256 qam8
9202750000-4.538256 qam9
10210750000-4.538256 qam10
11218750000-4.738256 qam11
12226750000-538256 qam12
13234750000-5.238256 qam13
14242750000-5.538256 qam14
15250750000-5.538256 qam15
16258750000-5.738256 qam16
17266750000-5.538256 qam17
18274750000-5.538256 qam18
19282750000-5.538256 qam19
20290750000-5.738256 qam20
21298750000-5.738256 qam21
22306750000-5.538256 qam22
23314750000-5.538256 qam23
24322750000-5.238256 qam24
1Locked38.625102310227
2Locked38.932619424
3Locked38.947684757
4Locked38.933565563
5Locked38.670844144
6Locked38.928506259
7Locked38.627537022
8Locked38.624206056
9Locked38.930416335
10Locked38.954256363
11Locked38.975746748
12Locked38.926246556
13Locked38.937124085
14Locked38.66255459
15Locked38.945283611
16Locked38.97177460
17Locked38.97567860
18Locked38.945474861
19Locked38.930015438
20Locked38.945403107
21Locked38.950592235
22Locked38.95508594
23Locked38.95914931
24Locked38.93390361
2ATDMA00210
3ATDMA0000
4ATDMA0000
5ATDMA0000
  • 13.9K
  • 1.08K
  • 2.82K
Message 2 of 7
Re: Help on HUB 3 Levels - Dropping Connections
Upstream too high, downstream too low. Indicative of either a cable or box fault, unless there is an area fault. Check all connections are tight, then:
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
Stevego
  • 37
  • 7
Message 3 of 7
Hi Tudor,
Many thanks for your prompt advice.
Have checked with 150 automated system - no Area faults, no faults on testing my connection!.
First thing it says is reboot the HUB - done this almost daily - clears the error until the next time!
Then more things that have been checked loads of times - then the HUB is in Modem Mode - this is causing the problems, no it's not. I am using the same router, same setup, as when it was using a HUB 2...
Then finally go back to calling 150 loop!!!! loop!!!!!.
Will try calling Customer Services as you suggest - maybe someone from VM will see this post and help?
Thanks again
Steve .
Carley_S
  • 3.12K
  • 163
  • 263
Message 4 of 7
Hi @Stevego
Welcome back to the community forums
Sorry to hear you're having issues with your broadband at this time and have not been able to get the help when calling 150. Checking the systems at our side I can see that your power levels are still  out of spec and we'll need to book a technician to investigate further.
Please join me on private message so I can locate your account and pass account security. You can see your private messages at the top of the page, in the envelope icon
Carley - Forum Team
Carley_S
  • 3.12K
  • 163
  • 263
Message 5 of 7
Thanks so much for your private message @Stevego
I have now booked you a visit for your power level issue – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
There will be no charge for this visit unless:
•    The technician diagnoses the faults as not being caused by our network/equipment
•    The technician discovers that the fault or problem relates to your equipment
•    The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Carley - Forum Team
Stevego
  • 37
  • 7
Message 6 of 7
Hi Tudor & Carley, + Andy
Technician (Andy 925158) came on Wednesday 1st Feb as planned - sorted the levels out, all seems OK now.
Many thanks to all three of you for your assistance and advice.
Steve
John_GS
  • 15.7K
  • 798
  • 1.46K
Message 7 of 7
Thanks for coming back to the thread with this update, Steve.
We're glad everything has been sorted 🙂
Do pop back if you ever need further assistance.
Best wishes,
John_GS
