Help needed setting up on fire tv
charmayneoakey
We have bought a fire tv with alexa built in as mum can use virgin remote, how can I set this up
2 REPLIES 2
Hi charmayneoakey
Is that a firetv set, and if so which manufacturer model number, or a fireTV cube, and if it's the cube which version?
Also which VM TV set top box?
https://www.virginmedia.com/care/tv-fault/which-tv-box
Dave
The do's and don'ts.
Legend
"how can I set this up" - Has the device come with a manual / quick start instructions ?
