Grandadoc
Help installing WiFi Booster Kit
As the WiFi coverage in my bungalow is very poor I was supplied with a Booster Kit.
As I have only one mains socket where my computer and Hub are located this presents me with a problem.
I can utilise the one mains socket to power the Hub and smaller booster but how can I connect the larger booster in the same room with no more sockets.
Is it essential to not use an extention cable from another room?
  • 10.51K
  • 667
  • 1.4K
jb66
Re: Help installing WiFi Booster Kit
You can put the larger booster for set up purposes in on an extension cables its final resting place then can go in the wall
