TheCJ174
Help connecting TP-Link Archer VR600 router to Virgin Hub 3
Hi there,
I've just bought a TP Link Archer VR600 Modem Router and I'm trying to establish a wireless connection with my Virgin Media Hub 3.0, has I understand it I need to create a Static IP address connection but in order to do so I need to contact my ISP.
Anyone there that could help me with this, would be very appriciated.
Regards, TheCJ174.
  • 12.82K
  • 504
  • 1.16K
Re: Help connecting TP-Link Archer VR600 router to Virgin Hub 3
You got the wrong router send it back or use EWAN port in Wireless Router Mode.
Page 16
https://static.tp-link.com/1910012217_Archer%20VR600(b)(EU)(AU)_V2_UG.pdf
Once done only connect your router to the right port on the hub and put the hub into modem mode.
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
  • 37
mkaminski100
Below is the best instruction I could find.
Please note that you should use the "LAN4/WAN" socket on the router, not the RJ11 connector!
https://www.amazon.co.uk/review/R3QNIKK9DAGKXL/ref=cm_cr_srp_d_rdp_perm
