Liveammo
  • 60
Message 1 of 34
Heavy rain, No WIFI
I'm losing broadband/internet connection when it rains heavily. This has happened in the past although I wasn't sure what was causing the problem. In the last 3 months, i've noticed a regular pattern - whenever it rains I lose connection. I haven't reported this to-date due to the Covid-19 lockdown as I don't expect anyone to come out to fix the problem. As things are normalising to some extent, i would like to know the following:
1. Is this a problem I can attend to myself? Preferably with a video tutorial or easy-2-understand guideline.
2. Alternatively, can i book an engineer online?
paultechy
  • 19.74K
  • 1.74K
  • 4.32K
Message 2 of 34
Re: Heavy rain, No WIFI
does the internet work OK on wired connections?, since sounds like possible water getting into the coax cabling feed this is something an engineer would need to look into, can wait a day or so for the forum staff to arrange this.
Steven_L
  • 4.62K
  • 338
  • 460
Message 3 of 34
Hey Liveammo,
As @paultechy asked above, do you have issues with a wired connection at the same time that you lose your WiFi connection.
Is there any damage to your omni-box on the brown box on your outside wall? This maybe affecting your connection.
Do you have any issues with your TV during the down time you have with your WiFi?
Steven_L
Liveammo
  • 60
Message 4 of 34
Apologies for the late reply.
Yes the problem occurs both with WIFI and wired connections. To clarify this occurs due to "heavy rain"
Liveammo
  • 60
Message 5 of 34
Sorry if repeating the same answer twice
Lisa_CC
  • 3.97K
  • 236
  • 438
Moderator
Moderator
Message 6 of 34
Hi there Liveammo,
Thanks for popping back. I understand you're still having ongoing issues with your WiFi connection but can I ask if you can reboot your Hub for me? I've found your details using the information we have on here and can see that it's been a while since you rebooted. I'd like to see the fresh live details if it's possible so I can help. Can you also confirm whether your Hub is in full router mode (and not in modem mode) so we can check the full details.
Lisa
Liveammo
  • 60
Message 7 of 34
Hi Lisa_CC
Rebooted the Super hub.
Yes router mode only.
The internet works flawlessly 99% of the time via WIFI and ethernet. The loss of internet (both WIFI and ethernet) only occurs during heavy rain. I'm assuming this is in relation to external wall components/box which is playing up when rain water is affecting internet access with rain water sips in.
Liveammo
  • 60
Message 8 of 34
any advice?
gary_dexter
  • 30.47K
  • 1.89K
  • 4.05K
Message 9 of 34
@Liveammo wrote:
any advice?
Mod replies can take 5-7 days
Liveammo
  • 60
Message 10 of 34
Thanks Gary...
Gary if you don't mind me asking... are the Mods VM authorised representatives? I recall the one above informing they have access to view my account details? If yes, I'm assuming the forum/mod is no different to calling VM via the phones (same level of customer service)?
