garbs123
Having to reboot Hub 3 often
Hi everyone,
Recently I’m having to reboot my Hub 3.0 pretty often - every couple of days; sometimes twice in one day! All my wifi devices just drop wifi and the green wifi icon lights up on the front.
Do we think my hub is on its way out and needs replacing?
Tags (3)
  • 35.06K
  • 3.41K
  • 6.67K
Re: Having to reboot Hub 3 often
May just be wifi interference.
So are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Is the base light a steady white(ish) or flashing green when it happens?
