  • 6
Message 1 of 13
Having issues connecting to virgin superhub 3 with my iPad and iPhone since updating the latest iOS.
Since the last iOS update, I can’t connect to my Wi-Fi (superhub 3). I have followed all instruction on website (reboot, factory reset, checked all connections). Managed to get rid of weak security tab by following the advice on the community questions (used an iPad pre iOS 14). My iPhone and iPad both see the router, but won’t connect. We’ve not added any other new devices.
Any suggestions (getting through to Virgin for the last three days is beyond a joke now).... yes I understand it’s ‘COVID-19 cover, but you still charge the full amount.. so as a customer I think we can expect a full service?)....
thanks for any hints and tips.
cheers
Dean
Tags (1)
  • 3.64K
  • 282
  • 511
Superfast
Message 2 of 13
Re: Having issues connecting to virgin superhub 3 with my iPad and iPhone since updating the latest iOS.
cheers
Dean
Shouldn't you be contacting Apple?
  • 21.1K
  • 2.27K
  • 4.2K
Message 3 of 13
On iOS 14 go to Settings > Privacy > Local Network and make sure access is enabled for the Connect app.
  • 24.72K
  • 1.43K
  • 3.15K
Message 4 of 13
Connect to it in what sense?
You can access the admin page in a browser.
  • 6
Message 5 of 13
Not helpful!
  • 6
Message 6 of 13
I can’t connect with the app, when I scan the password, it can’t find the router. I have an iPad without ios14, so I can get I to the router via 192.168.0.1
  • 6
Message 7 of 13
I can access admin via an iPad that doesn’t have ios14.
  • 24.72K
  • 1.43K
  • 3.15K
Message 8 of 13
What do you need to use the app for that you can’t do in the admin pages?
  • 3.64K
  • 282
  • 511
Superfast
Message 9 of 13
@Deano737 wrote:
Not helpful!
I assume this was pointed towards me (You didn't quote my post).
How do you expect VM to be aware of all software changes from third parties?
If other devices are working then it's nothing to do with VM.
  • 6
Message 10 of 13
I’m trying to get it to work, so I’m asking other virgin customers that might have had the same issue, I’m surely not the only apple user that has the issue since the last update. As VM is my service provider, i can only ask them... BT wouldn’t be able to answer it, and APPLE won’t deal with the connection issue... so instead of pointing out things that are obvious, but don’t help resolve the issue.. maybe constructive suggestions... I’ve tried to get through to Virgin, but there is no answer. When i reboot the router, I can log on the wifi for about 30 min, then it drops out again.
