Haven't received return packages for faulty wifi pods
BrokenInternet
Have been told several times that return packages are being sent to me for the return of faulty wifi pods.
At least 3 times now I have been told this, but no packages have been sent. This has prevented me from getting more pods as I have been told I am limited to 3 pods.
I don't think this is so much to ask for
1 REPLY 1
Ryan_N
Hi Brokeninternet,
Thank you for your post and welcome back!
Sorry to hear about this - it should just be a relatively easy straight swap, which doesn't seem to have been the case for you. I will send you over a private message so I can arrange this to be sorted for you.
Cheers,
Ryan.
