toontoon
  • 35
Message 1 of 58
Have to reboot super hub 3 daily
New to the community. Hope you can help?
At least once a day (and often more) we lose access to broadband - both ethernet and wifi. The lights on the hub 3.0 suggest all is fine, but the only solution is to reboot the hub. It then takes approx 5-10 minutes for everything to come back online and you can see the hub reboot numerous times. Wifi becomes available, then stops and so on until everything settles down.
When accessing the superhubs interface it is extremely slow - the slowest being DHCP - almost unusable - minutes to load the reservation list (for a list of 5).
Anyone else having these problems or got a solution? This has been going on for a few months now. Have done all the normal - factory reset, hard reboot, etc.
Thanks all.
Aaron2
  • 799
  • 89
  • 139
Well-informed
Message 2 of 58
Re: Have to reboot super hub 3 daily
Can you post the results from http://192.168.0.1/ > Check Network Status then paste everything from each tab?
** I work for VirginMedia but all opinions posted here are my own.
SCA1972
  • 5.73K
  • 652
  • 1.92K
Message 3 of 58
The Hub 3 (they dropped the Super moniker) is notorious for the slow GUI and this can only be resolved by a firmware fix from VM.
With regard to the connection dropping, if you want help from the community then posting some hub stats would be a good start.  Alternatively you can wait for the VM staff to get to this thread in a few days.
To get hub stats go to http://192.168.0.1/ (or http://192.168.100.1/ if you are in modem mode) to get the VM hub GUI. Don't login (unless you have a Hub 3 and this is your first visit to the hub GUI, which does require you to login) but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. If using screenshots be careful to edit out or obscure any reference to your WAN IP or MAC address in the log to protect your privacy.  Images will take time to appear on the forum as they need to be approved by moderators. If you copy and paste the log then the forum will automatically censor this sensitive information.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
toontoon
  • 35
Message 4 of 58
Thanks for coming back so quickly. Firmware update - I definitely need that - as the GUI is so sluggish. Here are the results as requested.
Downstream:
1 211000000 -0.4 38 256 qam 10
2 187000000 1 38 256 qam 7
3 195000000 0.5 38 256 qam 8
4 203000000 0 38 256 qam 9
5 219000000 -0.5 38 256 qam 11
6 227000000 -0.7 38 256 qam 12
7 235000000 -1.2 38 256 qam 13
8 243000000 -1.7 38 256 qam 14
9 251000000 -2 38 256 qam 15
10 259000000 -2.4 38 256 qam 16
11 267000000 -2 38 256 qam 17
12 275000000 -1.2 38 256 qam 18
13 283000000 -1 40 256 qam 19
14 291000000 -1.2 38 256 qam 20
15 299000000 -1 38 256 qam 21
16 307000000 -1.2 38 256 qam 22
17 315000000 -1.4 38 256 qam 23
18 323000000 -1.5 38 256 qam 24
19 379000000 -3 38 256 qam 25
20 387000000 -4 38 256 qam 26
21 395000000 -4.7 38 256 qam 27
22 403000000 -5 38 256 qam 28
23 411000000 -5 38 256 qam 29
24 419000000 -5 38 256 qam 30
1 Locked 38.6 16 0
2 Locked 38.9 82 0
3 Locked 38.6 25 0
4 Locked 38.9 16 0
5 Locked 38.9 18 0
6 Locked 38.6 15 0
7 Locked 38.9 9 0
8 Locked 38.9 9 0
9 Locked 38.9 20 0
10 Locked 38.9 1 0
11 Locked 38.9 11 0
12 Locked 38.9 16 0
13 Locked 40.3 4 0
14 Locked 38.9 9 0
15 Locked 38.6 10 0
16 Locked 38.9 15 0
17 Locked 38.9 14 0
18 Locked 38.9 29 0
19 Locked 38.6 4 0
20 Locked 38.6 18 0
21 Locked 38.6 22 0
22 Locked 38.6 14 0
23 Locked 38.6 9 0
24 Locked 38.9 12 0
1 53700016 4.35 5120 64 qam 74
2 46200103 4.225 5120 64 qam 75
3 39400030 4.175 5120 64 qam 76
4 60300000 4.45 5120 64 qam 73
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
28/12/2019 06:35:6 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
28/12/2019 06:35:6 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
28/12/2019 06:35:7 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
28/12/2019 10:01:32 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:54:56 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:54:57 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:54:57 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:55:1 Warning! Lost MDD Timeout;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:55:3 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:55:4 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 07:55:5 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
29/12/2019 10:46:22 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 05:20:5 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:3 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:3 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:4 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:4 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:7 Warning! Lost MDD Timeout;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
30/12/2019 06:26:11 Warning! RCS Partial Service;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39 critical No Ranging Response received - T3 time-out;CM-MAC=XX;CMTS-MAC=XX;CM-QOS=1.1;CM-VER=3.0;
  • 20.8K
  • 2.21K
  • 3.68K
Message 5 of 58
There is no current VM firmware update to fix the issue - whether there ever will be - who knows!  Only certain way to fix it is to do as many on here do and put the Hub into modem mode and use your own router.
toontoon
  • 35
Message 6 of 58
Have been away for new year - but now back, and had to reboot the router this morning again twice within 20 minutes.
Is anyone able to offer any advice?
toontoon
  • 35
Message 7 of 58
I posted them as requested, any clues?
Already had to reboot twice today!
SCA1972
  • 5.73K
  • 652
  • 1.92K
Message 8 of 58
Power levels appear to be within the recommended range, although they are quite spread out between -5 and +1 which is a little unusual.  The daily "RCS Partial Service" errors in the log are not good and indicate that something is wrong with your connection.
@ModTeam Please can you ask one of the forum team to visit this thread and check @toontoon's connection as the log doesn't look healthy.
Scott
David_Bn
  • 4.39K
  • 203
  • 352
Message 9 of 58
Good Afternoon toontoon,
Thanks for your posts on our Community Forums and a very warm welcome to you
Let's take a closer look into this issue to see if this can be resolved for you
Please check out the purple envelope in the top right hand corner of the screen for a PM from me
Kindest regards,
David_Bn
toontoon
  • 35
Message 10 of 58
Unfortunately the problem has returned. Engineering visited and installed a new hub. Problem resolved although would still have to reboot weekly. Over time the problem has reoccurred to the point that now we have to reboot once or twice a day. Please can you help? Thanks.
