  • 83
  • 15
jra505
Dialled in
Message 1 of 19
Have to keep restarting Super Hub 3.0
Hello
I'm on the 300mbps service which is normally very reliable, however over the last couple of weeks I've found that the Internet occasionally drops out and the only way to reconnect is to restart the Super Hub 3.
This is on both wired and wireless connections.
The Super Hub 3 light is a sort of red/pink colour, and doesn't change when the Internet drops out. Any help would be much appreciated.
jra505
  • 1.07K
  • 52
  • 143
MikeRobbo
Knows their stuff
Message 2 of 19
Re: Have to keep restarting Super Hub 3.0
Firstly set up a BQM at thinkbroadband.com - this will give you an insight into what is happening with the signal coming into the property, it will take a few hours to get any kind of trend showing.
then
It may be a good idea to carry out a factory reset on the Hub …
With the Hub Powered on use a paperclip or similar do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
then
Type 192.168.0.1 into your browser URL bar and press enter.  When the page appears DO NOT LOG IN but click ‘Check Router Status’. Copy and paste the contents of each tab onto here, a Guru will be along soon to decipher the info.
  • 9
rosh_118
Message 3 of 19
I've been having this problem daily since October.  We're on our third hub, which was working well for 4 days, but it's just happened again.  I'm hoping it's a one off...time will tell...
In the first instance, I'd get a new hub to see if that resolves the problem.
  • 83
  • 15
jra505
Dialled in
Message 4 of 19
Here is the BQM chart. As you can see, a great big red block for much of the day.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d607d149cb6ece5a431ca52f93b526bdc9...
Confusing thing is, it's red now, but the internet does seem to be working. Does that make any sense?
jra505
  • 12.92K
  • 513
  • 1.18K
Message 5 of 19
Hub 3 bug might be better to get your own router and use the hub in modem mode.
  • 6.6K
  • 511
  • 1.1K
Legend
Message 6 of 19
As the OPs problem is with both wired and wireless devices it’s much more likely to be a local circuit problem.
  • 10.71K
  • 1.09K
  • 1.71K
Message 7 of 19
To paraphrase Einstein......  “The definition of insanity is doing the same thing over and over again, but expecting different results.”
So why do you think a fourth Hub3 will solve the issue?  The problem clearly lays elsewhere - either upstream or downstream of the Hub itself.
  • 83
  • 15
jra505
Dialled in
Message 8 of 19
Sorry I should have said, I'm already running it in modem mode and using an Archer C9 (running dd wrt) as my router.
  • 83
  • 15
jra505
Dialled in
Message 9 of 19
Can you please explain why you think its likely to be a local problem, based on it affecting both wired and wireless? Surely if the Internet goes down it will affect both?
  • 9
rosh_118
Message 10 of 19
We’ve had all the upstream and downstream levels checked, they’re all fine.
Few days on now though and we’re back to daily disconnections.  We keep getting refurbished hubs rather than brand new ones.  Unfortunately no one at virgin has been able to come up with an answer yet.
