Dan1elXIII
  • 9
Message 1 of 17
Have WiFi but nothing wired is working
This morning I had no internet going to my PC but had WiFi in the house so I tried resetting router, changed Ethernet cables and restarted my PC several times. Still tells me I have Unidentified network in my network settings.
things I’ve tried - Reset button on router, Network Reset in Network settings, new cables from router to PC and turned the router off for an hour or so.
  • 22.35K
  • 2.4K
  • 3.99K
Message 2 of 17
Re: Have WiFi but nothing wired is working
What Hub model is it and what are the various lights on the Hub showing/doing ?
Dan1elXIII
  • 9
Message 3 of 17
I have the Hub 3 and atm just the yellow power light at the bottom
lotharmat
  • 838
  • 56
  • 118
Well-informed
Message 4 of 17
Have we established on here that 'yellow' can mean just about anything!
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Dan1elXIII
  • 9
Message 5 of 17
When I go to the router I do not see an option for router options just to log in
  • 22.35K
  • 2.4K
  • 3.99K
Message 6 of 17
If its not showing a "router staus" icon at the bottom/middle of the log in poage - it means you have never logged in previously.
If that is the case then log in change the password and save/apply changes and log out. Then the Status icon will automagically appear.
Dan1elXIII
  • 9
Message 7 of 17
Its not letting me post the router status as one so here is each one.
https://gyazo.com/a27a43b39a37563cbfcc92d3fcf4a897
331000000
Locked
Ranged Upstream Channel (Hz)
46200026
Locked
Provisioning State
Online
13310000009.438256 qam25
22030000007.538256 qam9
32110000007.138256 qam10
4219000000738256 qam11
52270000006.437256 qam12
6235000000637256 qam13
72430000005.538256 qam14
82510000005.938256 qam15
92590000006.637256 qam16
102670000007.338256 qam17
112750000007.538256 qam18
12283000000838256 qam19
132910000008.338256 qam20
142990000008.938256 qam21
15307000000938256 qam22
163150000009.338256 qam23
173230000009.338256 qam24
18371000000938256 qam26
193790000008.538256 qam27
203870000008.538256 qam28
213950000008.138256 qam29
224030000008.338256 qam30
234110000008.438256 qam31
244190000008.138256 qam32
1Locked38.600
2Locked38.960
3Locked38.650
4Locked38.960
5Locked37.640
6Locked37.650
7Locked38.660
8Locked38.690
9Locked37.640
10Locked38.630
11Locked38.650
12Locked38.650
13Locked38.900
14Locked38.6180
15Locked38.9180
16Locked38.9110
17Locked38.9170
18Locked38.900
19Locked38.950
20Locked38.900
21Locked38.630
22Locked38.660
23Locked38.650
24Locked38.6110
Dan1elXIII
  • 9
Message 8 of 17
14620002641.5512064 qam1
22579999640512064 qam4
33260001940512064 qam3
43939996641.5512064 qam2
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ldJKDHSUBsgvca69834ncxv98
SFID20352
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID18573
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Dan1elXIII
  • 9
Message 9 of 17
04/05/2021 15:58:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:57:28Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:56:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:55:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:49:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:30:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:30:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 15:30:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 14:36:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 11:33:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 11:33:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 11:33:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 11:33:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 11:33:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 22.35K
  • 2.4K
  • 3.99K
Message 10 of 17
Nothing out of "spec" in the stats - others need to comment on the logs.
Are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
What Hub is it and what are the various Hub lights showing/doing when this happens?
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
