hope someone can advise. Been having general drops over last few
weeks, hub changed from a 4 to a 5. Still seeing occasional wifi drops. Hub was changed plus all cable inside and outside to wall plate. It 1gb but coax to the house.
Tried Virgin without alot of success as they dont see any issues, but before i did a reset i was seeing over 1m errors on a single channel. Others were small in number and no Post RS errors.
Upstream seems fine.Current number after a reset about 2 hours ago is now this for downstream. Any advice greatly received
Acquired Downstream Channel(Hz) | 331000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
ChannelFrequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1 | 331000000 | 6.3 | 42 | QAM 256 | 25 |
2 | 139000000 | 6.7 | 42 | QAM 256 | 1 |
3 | 147000000 | 6.5 | 42 | QAM 256 | 2 |
4 | 155000000 | 6.5 | 42 | QAM 256 | 3 |
5 | 163000000 | 6.4 | 42 | QAM 256 | 4 |
6 | 171000000 | 6.3 | 39 | QAM 256 | 5 |
7 | 179000000 | 6.3 | 40 | QAM 256 | 6 |
8 | 187000000 | 6.3 | 42 | QAM 256 | 7 |
9 | 195000000 | 6.3 | 42 | QAM 256 | 8 |
10 | 203000000 | 6.2 | 42 | QAM 256 | 9 |
11 | 211000000 | 6.3 | 42 | QAM 256 | 10 |
12 | 219000000 | 6 | 42 | QAM 256 | 11 |
13 | 227000000 | 5.6 | 42 | QAM 256 | 12 |
14 | 235000000 | 5.2 | 42 | QAM 256 | 13 |
15 | 243000000 | 4.8 | 42 | QAM 256 | 14 |
16 | 251000000 | 5.3 | 42 | QAM 256 | 15 |
17 | 259000000 | 5.5 | 42 | QAM 256 | 16 |
18 | 267000000 | 5.5 | 42 | QAM 256 | 17 |
19 | 275000000 | 5.8 | 42 | QAM 256 | 18 |
20 | 283000000 | 6.1 | 42 | QAM 256 | 19 |
21 | 291000000 | 6.1 | 42 | QAM 256 | 20 |
22 | 299000000 | 5.9 | 42 | QAM 256 | 21 |
23 | 307000000 | 5.9 | 42 | QAM 256 | 22 |
24 | 315000000 | 5.9 | 42 | QAM 256 | 23 |
25 | 323000000 | 6.1 | 42 | QAM 256 | 24 |
26 | 339000000 | 6.1 | 42 | QAM 256 | 26 |
27 | 347000000 | 5.6 | 42 | QAM 256 | 27 |
28 | 355000000 | 5.1 | 42 | QAM 256 | 28 |
29 | 363000000 | 4.9 | 42 | QAM 256 | 29 |
30 | 371000000 | 4.8 | 42 | QAM 256 | 30 |
31 | 379000000 | 5 | 42 | QAM 256 | 31 |
1 | Locked | 42 | 0 | 0 |
2 | Locked | 42 | 0 | 0 |
3 | Locked | 42 | 0 | 0 |
4 | Locked | 42 | 0 | 0 |
5 | Locked | 42 | 0 | 0 |
6 | Locked | 39 | 100745 | 0 |
7 | Locked | 40 | 48 | 0 |
8 | Locked | 42 | 0 | 0 |
9 | Locked | 42 | 0 | 0 |
10 | Locked | 42 | 0 | 0 |
11 | Locked | 42 | 0 | 0 |
12 | Locked | 42 | 0 | 0 |
13 | Locked | 42 | 0 | 0 |
14 | Locked | 42 | 0 | 0 |
15 | Locked | 42 | 0 | 0 |
16 | Locked | 42 | 0 | 0 |
17 | Locked | 42 | 0 | 0 |
18 | Locked | 42 | 0 | 0 |
19 | Locked | 42 | 0 | 0 |
20 | Locked | 42 | 0 | 0 |
21 | Locked | 42 | 0 | 0 |
22 | Locked | 42 | 0 | 0 |
23 | Locked | 42 | 0 | 0 |
24 | Locked | 42 | 0 | 0 |
25 | Locked | 42 | 0 | 0 |
26 | Locked | 42 | 0 | 0 |
27 | Locked | 42 | 0 | 0 |
28 | Locked | 42 | 0 | 0 |
29 | Locked | 42 | 0 | 0 |
30 | Locked | 42 | 0 | 0 |
31 | Locked | 42 | 0 | 0 |
