Pelliott
Message 1 of 11
HUB upgrade required ..
Can you advise how you get a replacement hub! we are still on super hub 2 , so about 5 behind the latest. Wasn’t offered anything newer at latest package change.. the signal is terrible, constantly cuts out and the feedback to the tv is unbearable..when hub is on the tv constantly flickers..
you can not even use the Virgin connect app for help as it is so old it doesn’t feature on it…
  • 1.89K
  • 120
  • 438
Super solver
Message 2 of 11
Re: HUB upgrade required ..
Pelliott
Message 3 of 11
Thanks but I’ve tried this in the past and same again there, it doesn’t allow you to connect to the older hubs through the app.. as only 3/4/5 are listed, when you click older hubs says can not support?
  • 35.1K
  • 3.41K
  • 6.68K
Message 4 of 11
A VM person should be able to help on here in a day or so
Tom_W1
  • 3.66K
  • 198
  • 342
Message 5 of 11
Hi @Pelliott thanks for your post here, although we're sorry to hear of your concerns raised here.
We've ran some checks here and there are no network outages, so everything should be running fine for you here.
In terms of a Hub upgrade, in order to receive this you would need to upgrade your broadband speed - the Hub 2 does support up to the M250 package so you'd need to go above this in order to receive the upgrade.
I hope this helps and if you wish to discuss the upgrade further, the team are available on the phones via 150 / 0345 454 1111.
Many thanks
Tom_W
Pelliott
Message 6 of 11
Thanks for this however your website states differently
What Hub upgrades am I eligible for?
This depends on what Hub you have.
I have the Super Hub 1, 2 or 2ac
Existing Virgin Media customers with a Super Hub 2ac, or older, can easily upgrade to a Hub 3, at no extra cost.
Download the virgin connect app and connect to the current Hub via 3G or 4G on your phone – without your Virgin WiFi being turned on. It will suggest to upgrade to the Hub 3 and you can collect this free from your local shop. There will be no new contract or price change.
Ayisha_B
  • 4.46K
  • 174
  • 396
Message 7 of 11
Hi @Pelliott,
I've had a peek at our systems and can see you spoke with our team this afternoon and they've ordered a Hub 3 for you 😊
If you need help with anything else, let us know.
Ayisha_B
  • 35.1K
  • 3.41K
  • 6.68K
Message 8 of 11
For completion... did you have to upgrade your package to get the Hub3 or was it just a straight swap?
Pelliott
Message 9 of 11
They have finally agreed to replace the hub and I did not need to change the package to get it 🙂
it has taken a while to organise and a few attempts so fingers crossed it appears!
thanks to everyone for their help
Ilyas_Y
  • 2.48K
  • 86
  • 218
Message 10 of 11
Hey @Pelliott, thanks for the update on the forums.
I'm glad that you have been able to get a new hub. 🙂
Let us know how it is once you get it! Send a picture as well so everyone can see.
Kind regards,
Ilyas.
Ilyas - Forum Team
