robjon
  • 48
  • 6
Message 1 of 43
HUB 5 problems
Set up my hub 5 last week. All mobiles, laptop and desktop are working as they should but the Samsung Galaxy Tab A (2016) connects ok but is very slow to load internet pages and on Facebook it won`t load pictures. I`ve still got my old hub. Can VM re-instate my old one as this is only a trial hub and obviously still has internal bug issues
robjon
  • 48
  • 6
Message 2 of 43
Reactivating Hub 3
Will VM reactivate my Hub 3 (hub 5 is u/s) and if so, how long will it take?
  • 19.55K
  • 800
  • 2.07K
Message 3 of 43
Re: HUB 5 problems
Easy way is to put the hub in modem mode and get a better wifi router with 1Gb ports.
  • 6.09K
  • 512
  • 1.57K
Message 4 of 43
Re: Reactivating Hub 3
Please do not double post. It causes confusion.
  • 6.09K
  • 512
  • 1.57K
Message 5 of 43
Re: HUB 5 problems
Phone VM and have your old Hub plugged in. They may re provision it right away if you explain the Hub 5 is not working.
robjon
  • 48
  • 6
Message 6 of 43
Re: HUB 5 problems
Why spend my money when it`s down to VM sending out buggy equipment
  • 19.55K
  • 800
  • 2.07K
Message 7 of 43
Re: HUB 5 problems
Your in for a painful couple of weeks then.
dessy
  • 69
  • 7
Dialled in
Message 8 of 43
Re: HUB 5 problems
ive got the same tab 16 and after doing a factory reset i had the same problems as you so i told my tablet to forget my router and reinstalled bummer same again so told it to forget it again then ran youtube and got no internet so rebooted tab16 and used samsung internet and it said update availavble so updated and just put random url in then went back to youtube and i was back up to speed ..why i have no idea but its working now
dessy
  • 69
  • 7
Dialled in
Message 9 of 43
Re: HUB 5 problems
i had a problem with my hub 2 after upgrading to hub 3 and i just rang vm and they turnerd my hub 2 back on in the same phone call so all in all 30 mins is all it took . dont forget to ring 151 ok
robjon
  • 48
  • 6
Message 10 of 43
Re: HUB 5 problems
Why`s that then
