Mumfordd04
HUB 5 Flashing Blue Light
Had my Internet completely drop. I checked my router and it has a flashing blue light. It has it for about 30 minutes and then turns solid white but no devices can connect to it. Any attempt to reset or hard reset it have failed and resulted in another 30 minutes of flashing blue lights and a solid white light with no Internet.
Chris_W1
  • 6.57K
  • 275
  • 440
Re: HUB 5 Flashing Blue Light
Hi Mumfordd04, thanks for the message and welcome to the forums.
I have looked into this and will send you a private message.
Kind regards, Chris.
