jps2023
Message 1 of 5
HUB 4 USELESS
Just received my second hub 4 this morning
installed taken the old one back to post to yodel
been of for a few hours then starts doing the same thing
it re boots resets itself to factory and removes my personalised ssid and passwords
these hubs are useless !!!!
  • 35.11K
  • 3.41K
  • 6.68K
Message 2 of 5
Re: HUB 4 USELESS
Dont disagree - was it actually working fine before? It can take some time to stabilise after first connecting and switching on and doing firmware updates  - but you might try this first and if it doesnt work consider just using it in modem mode with your own router....
__________________________
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker so log in and change them back to what they were/should be.
  • 20.49K
  • 828
  • 2.2K
Message 3 of 5
Re: HUB 4 USELESS
Just use it in modem mode and get a better router with 1Gb ports
Ilyas_Y
  • 2.48K
  • 86
  • 218
Message 4 of 5
Re: HUB 4 USELESS
Hi there @jps2023, thanks for reaching out to us on the forums.
I'm sorry to hear about the issues with the Hub 4 😞
May I ask how the hub has been recently? Does the issue still continue?
Let us know.
Kind regards,
Ilyas.
Ilyas - Forum Team
jps2023
Message 5 of 5
Re: HUB 4 USELESS
Through trial and error looks like i have solved the issue !
Hub 4 have firmware issues.
When personalising the ssid and passwords and using dual 2.4 and 5 ghz wifi disable channel optimisation
Pre set a channel to your liking on 2.4 and 5 ghz do not let the hub choose !
Save and it will remain stable !
