  • 32.62K
  • 1.78K
  • 5.74K
Message 11 of 19
Re: HUB 4 CROYDON
then you must use the personalized link VM sent you that allows you to order.
if you do not have that then you can't order.
VM do not have to upgrade anyone if they have hardware that can support the current level of service
  • 6.53K
  • 1.25K
  • 1.78K
Message 12 of 19
Re: HUB 4 CROYDON
Hello
I have raised this too the forum team somebody will have a look.
Regards Mike
  • 1.48K
  • 209
  • 701
Message 13 of 19
Re: HUB 4 CROYDON
@Whitmow644 wrote:
Hi thank you for that
Please see the link above  my message 6 of  7 , this what is being sent to  VM customers in non gig1 areas , and its veracity has been confirmed by the VM Executive Team , and that its compatible in non gig 1 areas
 take care
William
No it's being sent out to some VM customers in some areas where there is a degree of over utilisation and it is thought that the Hub 4's ability to bond more downstream channels may help to improve matters somewhat; assuming that the local infrastructure has been upgraded to make use of this. If neither of these are true in your case then having a 4 rather than a 3 will make precisely zero difference to you (at best!)
Also why do you suppose that the 4 is 'more reliable' than the 3? The Hub 4 is comparatively new but (admittedly anecdotal) evidence from posters on this forum who have upgraded to the 4, would suggest that this simply isn't true at all.
  • 8
Message 14 of 19
Re: HUB 4 CROYDON
yes  they do ,as 2 people that i know who are in a non gig 1 are ahave had their hub 3 replaced
please check yr facts
  • 5.06K
  • 881
  • 2.06K
Message 15 of 19
Re: HUB 4 CROYDON
@Whitmow644 : whereas the Hub 4 indeed has its own issues , what it does offer is  a geater stability
I don't know who told you that load of old cobblers, nor why you'd choose to believe it.  If anything a Hub 4 is going to be less stable because DOCSIS 3.1 is much more demanding of line quality on account of operating at much higher modulation rates than previous hubs.
  • 32.62K
  • 1.78K
  • 5.74K
Message 16 of 19
Re: HUB 4 CROYDON
tenor
  • 1.68K
  • 49
  • 152
Moderator
Moderator
Message 17 of 19
Re: HUB 4 CROYDON
Hi All,
I just wanted to confirm that the Hub 4 is available to customer's living in a Gig 1 fibre area and also to a number of customers that we contacted by email to offer a free upgrade. The upgrade is available to the addressed recipient only.
I'm afraid that we're unable to provide a timeframe for when our Gig 1 fibre service will be available in Croydon, you will however be able to use the link here
to keep an eye on future plans for when the service will be available.
Regards,
Dean C
Community Moderator
  • 15.27K
  • 1.17K
  • 1.92K
Message 18 of 19
Re: HUB 4 CROYDON
@Dean_C wrote:
Hi All,
Regards,
Dean C
Community Moderator
thumb-3
  • 17.93K
  • 1.93K
  • 4.32K
Message 19 of 19
Re: HUB 4 CROYDON
Seems clear to me. If you’re not invited, you can’t have it.
Just because you want one, doesn’t entitle you to an invitation.
