Message 1 of 9
HUB 3 WIFI to Yamaha Amp
Just had a HUB 3 router installed and I cannot seem to get 'music cast' to work on the amp or the wi fi to work. Getting 'connected no internet'.
Smart TV, phone etc all finding WiFi and internet working.
Anyone any ideas?
  • 12.15K
  • 943
  • 1.56K
Message 2 of 9
Re: HUB 3 WIFI to Yamaha Amp
 It sounds like the Hub hasn't been activated yet.
VM have recently started pre-activating their equipment, and the box should call "home" and be activated within 30 minutes, however sometimes this fails and the advice is to sign into Service status at the top of this page and run a test against the equipment you are installing. By doing this VM will be able to reboot the box or put you in touch with the right team.
You could also try the following, call 0800 953 9500 to activate the box. You will need the box serial number, and your account number and area code.
You could also try contacting New accounts and Set Up for them to complete the setup and activation. That is 150 from a Virgin landline options 1,1,1 and 4 or 0345 4541111 from any other phone, options 1,1,2 and 4.
Mike Robinson
Message 3 of 9
Thanks for the reply but the hub is active and working. I'm connected to the wi fi using the internet on my phone, tablet etc
  • 3.67K
  • 288
  • 516
Superfast
Message 4 of 9
Could you confirm the model of the amp?
It may not like the 'Smart' Wifi, where 2.4Ghz and 5Ghz are on one SSID (Network name), and you may need to split them out into two, like below:
Anonymous
Not applicable
Message 5 of 9
You followed this setup procedure https://usa.yamaha.com/support/faq/audio_visual/GJA14160.html `
If other WiFi devices are connecting ok, then its a setting on the amp thats most likely causing the issue, are any error messages displayed?
Anonymous
Not applicable
Message 6 of 9
Message 7 of 9
Thanks. It's a Yamaha R-N602 Network receiver. Yeah, I followed the music cast set up. The wi fi says no internet access.
I log into the router have a look at the options.
Message 8 of 9
Thanks for everyones help on this. By splitting the router settings into 2g and 5g and (as per screen shot above) and turning smart wifi off I have managed to connect to music cast on my tablet (using 5g) at least. My phone (2g) is still causing and issue. It only finds the 2g and does not let me connect to the music cast.
  • 14.78K
  • 622
  • 1.42K
Message 9 of 9
Get a better router with 1Gb ports and use the hub in modem mode.
