HUB 3 WHEN REBOOTED DELETES SAVED NAME AND SETTINGS
Since I changed the name of my Hub 3 ( I was told to do this by Virgin to turn off Intelligent WiFi ) it automatically has gone back to original settings after rebooting. Any thoughts ?
  • 11.32K
  • 1.15K
  • 1.81K
Re: HUB 3 WHEN REBOOTED DELETES SAVED NAME AND SETTINGS
Shouldn't do this after re-booting but will if its been factory reset - did you do a pinhole reset? If not it would be worth doing. With the Hub "on" push in the pin on the back/side/bottom of the Hub with the end of a paperclip until you feel it at the “stop point” and hold for a "timed" 60 seconds do NOT restart the Hub after that. Then go in and rename your wifi ssid's and turn off smart wifi etc.
If that doesnt sort it then the Hub might be faulty and need replacing.
Many thanks will try this
