  • 26
Message 1 of 19
HUB 3 IP Address
EeeE
Hello,
Just had my hub 3 installed today, but have an issue with the standard static IP address this router uses. Unlike standard routers, or at least all those I've come across, this device uses 192.168.0.1 rather than 192.168.1.1. This has caused me a problem as I have come to figure out that I cannot access this router on my existing static IP based network. I can change that static IP address of the connected PC's to use a zero rather than a one in the third IP address field and then I can see the Virgin router. However, my NAS and media streamer devices are still inaccessible and I really do not want to mess around with those.
I assume that if I were to change those devices static IP address to follow the same changes as described above. For example, my NAS is on 192.168.1.100 and I change this to 192.168.0.100, then I ought to have no further issues. However, to avoid changing all connected devices static IP addresses etc, is there a way to change the router to reside on 192.168.1.1?
Or, for those network guru's out there, is there a smarter way to have everything on the same network?
Tags (2)
  • 1.63K
  • 90
  • 229
Superfast
Message 2 of 19
Re: HUB 3 IP Address
change the IP range in the DHCP settings on the hub
"DHCPv4"
My Broadband Ping - spgray
  • 24.55K
  • 1.41K
  • 3.12K
Message 3 of 19
You can't use 192.168.1.X as it's reserved for the Guest Network (whether you enable it or not).
  • 26
Message 4 of 19
Thanks for the prompt reply, but I use static IP addresses so am not using DHCP.
  • 26
Message 5 of 19
OK. So, if I change all my static IP addresses on my network devices to follow the 192.168.0.x form, will that fix my issue?
  • 24.55K
  • 1.41K
  • 3.12K
Message 6 of 19
Yes. Or you can use any other range on the hub apart from 192.168.1.x and 192.168.100.x
  • 1.63K
  • 90
  • 229
Superfast
Message 7 of 19
and now you've found out why doing that is a bad idea!
  • 24.55K
  • 1.41K
  • 3.12K
Message 8 of 19
There's nothing wrong with static IP's - providing the router supports the range you're using.
Again, modem mode and another router will help with that
  • 1.63K
  • 90
  • 229
Superfast
Message 9 of 19
static IPs are fine, but it's usually a better idea to set them from within the DHCP server, rather than phsyically setting them on the device itself.
doing it that way means you don't lose access to the devices should the DHCP server change and default to a different IP range.
  • 24.55K
  • 1.41K
  • 3.12K
Message 10 of 19
Actually most people would tend to do it the other way around and set the IP on the device rather than the router/DHCP server that's how it should be done anyway in best practices.
Especially in a work environment at the very least.
