on 04-09-2023 15:58
Hoping someone can help.
We recently went away on holiday and returned to the electricity in the kitchen being off which had defrosted the freezer causing damage. A few different people had keys but all swear that they never used or did anything that would cause it to be off. So we've worked out that if we could establish the time the washing machine with wifi disconnected from the network we could establish when it happened.
So is there anyway of getting this information from the hub?
Any help appreciated
on 04-09-2023 16:04
Do you have a BQM (below) running by any chance?
Then try..... In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to the Network Logs page. See if the clues are in there.
on 04-09-2023 16:34
Thanks for your reply, Ive taken a look and it does give some information about the past couple of weeks but nothing about specific devices connecting or disconnecting unfortunately
Thanks anyway
on 04-09-2023 17:22
It should report a Hub restart after a power loss. Someone else may comment more specifically soon.
on 04-09-2023 17:57
Unfortunately the hub didn't loose its power just the kitchen appliances
on 04-09-2023 18:43
Well that's an end to that theory of how to work out when then!! Thanks for your help anyway
