on 09-06-2023 09:25
My Hub 3 is displaying a constant red light, I'm having no issues with speed or connectivity at the moment and have tried the usual turning it off and on again, as well as factory reset.
on 09-06-2023 10:49
Hey symonds_chris,
Thank you for your post and welcome to the forums.
Sorry to hear about the issue you're having here. I will send you over a private message so that I can get this sorted for you.
Cheers,
Ryan.
