simon1988
  • 16
Message 1 of 8
HUB 3.0 Solid Yellow Light
Ever since I've had the Hub 3.0 I've noticed the light is yellow all the time (as pictures) and my wifi is terrible/dropping out
I've gone through the VM help and did a test in area (all ok) and reset the Hub but it's still constantly yellow
Is this the issue why my wifi is so poor?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 8
Re: HUB 3.0 Solid Yellow Light
Possibly - it has been mooted on here by VM Staff that a yellow light means bad wifi...
Hang tight for VM Staff to confirm!
Andrew-G
  • 6.99K
  • 1.22K
  • 3.06K
Message 3 of 8
It's also been mooted here by me that the "yellow light = bad wifi" is a load of old cobblers, and just because somebody at VM has put up a web page saying this doesn't make it so.
Yellow LED displays on Hub 3's are exceptionally rare though with several million Hub 3's in use they do crop up from time to time, and in every single case I've seen in this forum the Hub has been faulty and required replacement.  If poor wifi conditions generated a yellow LED, then we'd see it far more often because poor wifi and Hub 3 are synonymous.
I'll flag this for the staff to comment.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 4 of 8
Totally agree with you - and I remember your explanation!!
Travis_M
  • 902
  • 36
  • 68
Message 5 of 8
Hi @simon1988
Thanks for posting on our community forum!
Could you reboot the hub quickly for me so I can review the signal levels etc upon the reboot? 🙂
Let me know once done.
Travis_M
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 6 of 8
Hopefully the light won't be yellow when you reboot!
simon1988
  • 16
Message 7 of 8
Thanks, I've just rebooted
It's still yellow on the router
Travis_M
  • 902
  • 36
  • 68
Message 8 of 8
Thanks @simon1988
I'm going to private message you now to check on a few details, please keep an eye on your inbox.
Travis_M
