BasB85
  • 5
Message 1 of 12
HUB 2 - Connection issues
Hi there,
Im starting to having more and more issues with my original HUB 2 that i got back in 2013.
Both with the 2.4 and the 5ghz networks were they just stop working.
A reboot doesn't always resolves the issue.
Sometimes causes even more issues
I'm expected to work from home for the foreseeable future so how can i get a new HUB?
Dont need an engineer just the unit and a return label / parcel so i can send the old / current unit back.
PS the website is still a mess. logs you out everytime you try to use the help topics where they want to you log back in. over and over again...
Never been able to make changes to my package either only getting "oops something went wrong" error message
Tried texting but that didn't work.
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Message 2 of 12
Re: HUB 2 - Connection issues
Hello
You may still be able to order a hub 3 from the following https://www.virginmedia.com/shop/hub-swap.html?buspart=uk_app_connect2_hubswap VMare swapping the older hubs ready for the removal of the cooper phone lines, which is due to be completed end 2025. As it is a hub 2 if you can order a 3 then there will be no need to return the 2 as old kit.
Regards Mike
BasB85
  • 5
Message 3 of 12
Sadly since the website is still a mess i can't do this.
Just getting this.
"Oops! Something went wrong.
Sorry, we’re unable to change your package online."
Have been getting this for years and everytime i've been told that someone was going to fix that.
Any other way someone could help with this?
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Message 4 of 12
Hello
If you hang on a VM staff member will resolve this for you and get the hub ordered, this may take a few days.
Regards Mike
gary_dexter
  • 30.31K
  • 1.88K
  • 4.03K
Message 5 of 12
You can call, use the text service or wait for a mod to pick this thread up
BasB85
  • 5
Message 6 of 12
From what i've read online the phone lines are too busy and some people have been trying for days to get through.
As stated i tried the texting method but that didn't work either. Got nothing back.
I'll wait until someone comes back to me on here.
Steven_L
  • 4.62K
  • 338
  • 458
Message 7 of 12
Hey BasB85,
I can arrange for a new hub to be sent out for you but would need to take your details over a private message that I will send over in a moment and we can get passed account security and send the new hub out to you.
Steven_L
Seanbike
Message 8 of 12
I have exactly the same issues with my hub 2, also i get the message on upgrade to hub 3 message what can i do, i have had this hub for over 5 years it has never had a stable wifi connection dropping out on both 2.4 and 5, changing channel does nothing to fix the problem, takes about 10 mins 4 times a week to reset the hub Help please
BasB85
  • 5
Message 9 of 12
check if you can request a replacement. if not might be best to create your own post so that there isn't any confusion on what is resolved and not 😉
Steven_L
  • 4.62K
  • 338
  • 458
Message 10 of 12
Hey Seanbike,
I will drop over a private message in a moment, so that we can get this looked into further, I can see that you have an issue with your power levels as well.
Steven_L
