MrsEmm1103
HUB 1 NOT WORKING
I have the old type hub 1 and it's stopped working (all the lights are on at all times). We've tried all the problem solving things (checking connections, switching everything off and on again etc etc) but still nothing!
I tried an online chat earlier but by the time I finally got transferred to the correct department it was 25 minutes until they closed and nobody spoke to me.
Does anyone have any helpful tips I could try until I eventually get through to virgin?
  • 24.1K
  • 2.55K
  • 4.37K
Re: HUB 1 NOT WORKING
Call at 09.00 tomorrow or 08.00 on Monday and you should get through quickly.  As it belongs in the science museum now they will send a newer Hub out
You could try a pinhole reset. Make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
See if that kicks it into life,  If it does go in and change the wifi password back to the one you were using
MrsEmm1103
Thanks John, I'll give that a go 🙂
Hayley_S
  • 1.19K
  • 34
  • 87
Hello @MrsEmm1103.
Welcome to the community page, thank you for posting on here.
Sorry for the issues with your Hub-1, please can you tell me if this has now been fixed?
Look forward to your response.
Hayley
