Grey outside box
SMAY23
hi,
I have been trying to contact Virgin Media to organise someone to come out and look at the outside grey box as it is broken and coming loose when the weather is bad - we have had it since it was fitted a few years ago.
Thank you in advance for any information on how I can get this sorted.
3 REPLIES 3
Joseph_B
Hey @SMAY23,
Welcome to the Community Forums and thanks for the post.
Sorry to hearing you are having this issue, can you confirm for me with the box which is damaged is this connected to your property or not, can you please also provide us an image of this.
Joe
Good afternoon,
Yes it is connected to the outside of our property.
thank you
Joseph_B
Hey @SMAY23,
Thanks for confirming this for me, so I can look about getting this sorted for you I will need to confirm some information in a quick private message with you, if you have not used this feature before you can access it via the envelope at the top of your screen.
Joe
