  • 6
Green WiFi symbol constantly flashing on Hub 3
My Hub 3 constantly has the green WiFi symbol flashing but does not seem to be affecting anything. I have reset the hub but the light flashes after some time again. I held the WPS button in for 30 seconds as recently suggested in another post and the light went away but it came back on the following day. What is this flashing light indicating and is it a problem.
  • 652
  • 120
  • 204
Re: Green WiFi symbol constantly flashing on Hub 3
Hi, no theres no problem, its a known software issue which is being looked into.
Rich
Send Me a PM!
Here to help! I'm a Field Technician helping out from home. Find out more
REFER A FRIEND AND SHARE £100 BETWEEN YOU
****************** ASK ME HOW ******************
  • 15.74K
  • 1.65K
  • 2.69K
"known software issue" since day1 - judge for yourself when a fix will be rolled out 🙂
In short it is the Hub looking for a WPS connection. try pressing the Hub's WPS button for around 20secs, or if that doesn't work, try disabling the push button WPS in the Hub's settings. You can search the boards for further info on how to.
If it doesn't work for you - just use some black sticky tape 🙂
  • 7.56K
  • 596
  • 1.28K
Legend
The “flashing green LEDs” syndrome seems to be one of the few things that’s been fixed in the Hub4. Mind you other problems have probably been introduced!
  • 6
Thanks very much for the reply’s. Looks like black insulation tape will have to be used until the issue gets sorted.
  • 2.31K
  • 168
  • 304
Superfast
Or disable WPS?
