redr0bin
Green Lights on Hub 3 - No wifi
My internet's been out since 7am this morning and it's now nearly 7pm - almost 12 hours!
The power light flashes green with the wifi light being solid green (the dot with three lines), but then it will switch to both the power light and wifi light being solid green, with arrows flashing. It switches between the two and has been consistently since this morning.
I've tried ringing but no response, as usual. I've checked the wiring, everything is connected. I've restarted the router, i've rebooted it, i've reset it, etc. Done everything I can possibly think of. Service checks, done. Says there's nothing wrong.
I have no internet and have been relying on my phone's data, which is pretty shoddy consider we're paying £50 a month for virgin media, but not getting connection or responses from the team.
Not sure what to do now. Please help 😞
Benjamin20
Re: Green Lights on Hub 3 - No wifi
Yep, I have the same problem, tried everything to try to get it working again but still nothing. Although mine has been down for past hour. Can't get through to anyone on the phone either. Shocking service to be honest.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
redr0bin
I've done that, and I've called as well. It says there's nothing wrong with the area I'm in. When this has happened before, it was a similar issue, and they never had to send anyone in. All I needed to do was call and they fixed it on their end for some reason.
But again, they haven't been picking up my calls. They put me on hold, then hang up before I get through. So...
  • 22.45K
  • 2.4K
  • 4K
Best time to call and get a response is ~08.01 midweek.
What are they doing that is fixing it at your end ? Did you not ask ?
Retevens88
How did you resolve this?
I had mine installed this morning and 12 hours later the same issue you had
virgin don’t seem in a rush to get it sorted
