on 10-10-2020 16:15
I have been using the Hub 3 since May 2019 with no issues. However since April/May 2020 when using GlobalProtect for work the connection drops every 20/30 minutes or so meaning that I am unable to access my work’s corporate network or use the internet, even though my laptop says I am still connected to the internet. The temporary fix is turning GlobalProtect on and off but the same issue arises 20/30 minutes later. If I keep GlobalProtect turned off I have no internet connection issues, I also have no issues with any of my other devices.
I have tried turning off the Hub 3 firewall and have had my firm’s IT team replace my laptop (Thinkpad Yoga X1 running Windows 10) but to no avail. IT have also logged on to my laptop remotely to play around with things (including reinstalling GlobalProtect) but nothing has worked.
The only workaround for this issue is tethering my phone or going into the office (I have been doing the latter which is why I have lived with this issue for so long). I am concerned that if a second lockdown happens I will have to tether my phone full time which will be expensive and cost me personally (I do not have a work phone). My firm's IT team are at a loss as to what more they can do and at this stage my only option appears to be changing internet service provider to Sky who also operate in my area. I don’t really want to have to change provider as I like Virgin and don’t want the hassle but obvious I can’t have this issue persisting.
I would be grateful if somebody could offer me some options for resolving this so I can take a view as to whether I need to change provider or not.
on 11-10-2020 23:59
on 14-10-2020 08:42
Thanks I tried this but no luck
on 14-10-2020 08:50
Hello
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
on 14-10-2020 10:28
Thanks Mike. I will post the information from those tabs in separate posts so as not to exceed the character limit. I have checked all the cables etc and no issues there. Other than this issue (which arose back in April/May this year) I have otherwise had excellent internet connection, speeds and WiFi.
No network issues in my area either.
Downstream
1 | 298750000 | -11.2 | 35 | 256 qam | 21 |
2 | 138750000 | -6.7 | 36 | 256 qam | 1 |
3 | 146750000 | -7 | 36 | 256 qam | 2 |
4 | 154750000 | -7.5 | 36 | 256 qam | 3 |
5 | 162750000 | -7.7 | 36 | 256 qam | 4 |
6 | 170750000 | -8 | 36 | 256 qam | 5 |
7 | 178750000 | -8.2 | 36 | 256 qam | 6 |
8 | 186750000 | -8.5 | 36 | 256 qam | 7 |
9 | 194750000 | -8.7 | 36 | 256 qam | 8 |
10 | 202750000 | -9 | 36 | 256 qam | 9 |
11 | 210750000 | -9.7 | 35 | 256 qam | 10 |
12 | 218750000 | -10 | 35 | 256 qam | 11 |
13 | 226750000 | -10.2 | 35 | 256 qam | 12 |
14 | 234750000 | -10.7 | 35 | 256 qam | 13 |
15 | 242750000 | -11.7 | 35 | 256 qam | 14 |
16 | 250750000 | -11.7 | 35 | 256 qam | 15 |
17 | 258750000 | -10.9 | 35 | 256 qam | 16 |
18 | 266750000 | -10.5 | 35 | 256 qam | 17 |
19 | 274750000 | -11 | 35 | 256 qam | 18 |
20 | 282750000 | -11 | 35 | 256 qam | 19 |
21 | 290750000 | -11.2 | 35 | 256 qam | 20 |
22 | 306750000 | -10.9 | 35 | 256 qam | 22 |
23 | 314750000 | -10.9 | 35 | 256 qam | 23 |
24 | 322750000 | -11 | 35 | 256 qam | 24 |
1 | Locked | 35 | 7969 | 0 |
2 | Locked | 36.6 | 116 | 0 |
3 | Locked | 36.6 | 756 | 10801 |
4 | Locked | 36.6 | 120 | 0 |
5 | Locked | 36.3 | 82 | 0 |
6 | Locked | 36.6 | 142 | 0 |
7 | Locked | 36.6 | 112 | 0 |
8 | Locked | 36.3 | 152 | 0 |
9 | Locked | 36.6 | 69 | 0 |
10 | Locked | 36.3 | 228 | 0 |
11 | Locked | 35.5 | 413 | 0 |
12 | Locked | 35.7 | 559 | 0 |
13 | Locked | 35.7 | 1321 | 0 |
14 | Locked | 35.5 | 1461 | 0 |
15 | Locked | 35.7 | 3172 | 0 |
16 | Locked | 35.7 | 4049 | 0 |
17 | Locked | 35.5 | 3163 | 0 |
18 | Locked | 35.5 | 1292 | 0 |
19 | Locked | 35.5 | 1504 | 0 |
20 | Locked | 35.7 | 934 | 0 |
21 | Locked | 35.5 | 3134 | 0 |
22 | Locked | 35.7 | 790 | 0 |
23 | Locked | 35.7 | 785 | 0 |
24 | Locked | 35.7 | 1196 | 0 |
on 14-10-2020 10:29
Upstream
1 | 39400000 | 5.1 | 5120 | 64 qam | 4 |
2 | 46200000 | 5.1 | 5120 | 64 qam | 3 |
3 | 53700000 | 5.1 | 5120 | 64 qam | 2 |
4 | 60300000 | 5.1 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | ca69834ncxv9873254k;fg87dsfd; |
SFID | 10946 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 10945 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
14/10/2020 10:17:56 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/10/2020 01:16:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2020 11:31:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2020 09:14:45 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2020 06:24:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2020 18:51:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2020 16:41:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2020 14:42:23 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2020 14:42:23 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2020 11:29:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/10/2020 11:52:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/10/2020 17:08:43 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/10/2020 12:15:56 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/10/2020 12:15:49 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2020 21:34:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2020 18:09:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2020 08:13:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2020 17:08:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2020 14:13:26 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2020 14:13:26 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 14-10-2020 10:37
Several of your Downstream Power Levels are too low.
Your Upstream Power Levels are maxed out.
You will need an engineer visit to put things right.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
on 14-10-2020 11:09
Hello
I have escalated to the VM forum team, one of the VM staff will be along in this thread to resolve it for you.
Regards Mike
on 14-10-2020 11:36
Good morning @Gannicus1000
Thank you for your post.
So that I can book an engineer for you, I am going to need to drop you a PM.
Kind regards,
Zak_M
on 14-10-2020 12:13
Thank you for providing me that information over PM.
I have booked the tech to visit for the next available appointment, this is on the 17th between 12-4, If the time and date are not suitable for you, you are able to change this via your online account
Kind regards,
Zak_M
