SamWuE
GlobalProtect & Virgin Media Broadband Connection Dropping
I’ve been having regular issues with global protect and failing with our virgin media internet. I’ve tried resetting the routing multiple times and it seems fine when I hotspot from my phone. Any ideas?
Tags (2)
  • 1.95K
  • 125
  • 457
Super solver
Re: GlobalProtect & Virgin Media Broadband Connection Dropping
I've not had issues with VPNs over the VM network.
I always connect office laptops direct to the Hub using a network cable.
用心棒
  • 8.16K
  • 900
  • 2.68K
See if disabling Web Safe makes a difference; to disable:
FYI: if Web Safe needs to remain active on your network then  either:
  • manually set an alternative DNS for devices using GlobalProtect
  • allow the domains Web Safe is adversely affect
Have I helped? Click helpful.jpeg Mark as Helpful Answer and solved, or use thanks.jpeg Kudos to say thanks
