  • 9
Message 1 of 17
Gig1 Fibre - Slow Connectivity, SkyQ issues
Good morning all,
We recently had Gig1 Fibre installed on 04/08/2020 in the PM. The engineer fitted the relevant box in the kitchen and carried out a wired test which he reported OK. Once the engineer left, we tempted to run connection testing through the various devices and have run into a whole bunch of issues.
For added context, we occupy a 3 story house, with the kitchen being on ground level. We have the main SkyQ box on the ground floor, with a mini SkyQ box on level 2. This issues we are experiencing are as follows:
  • SkyQ boxes keep intermittently dropping out Internet connectivity when connected to the Hub4.
  • WiFi on the 2.4ghz band seems to be dreadful. Standing approximately 5 foot away from the router provides download speed of 43.7Mbps. Obviously this does not translate well with devices on the first and second floor that are connecting (I have seen download speeds as low of 3Mbps.
  • WiFi on the 5ghz band seems to be marginally better. Download speeds when standing 5 ft away show speeds of 279Mbps at the time of writing this post (the highest I have seen it from this distance is 490Mbps). On the second floor I can see download speeds on this band of approx 150-200Mbps at the most.
  • There is most certainly a black spot on the first floor somehow, with either band barely reaching 80Mbps in some areas (the opposite side of the kitchen, coincidentally).
Network diagnostics on the router show that there are issues with the WiFi connections, but it doesn't provide any further information than that. I have ran through the normal, reboot, reset, hardwire testing (I would need to retest in modem mode for an accurate result as I was using speedtest.net).
Ultimately I think there may be multiple knock on issues at hand:
  • The line and router has been incorrectly placed (it is in the corner of the kitchen, with about 0.5m clearance space between a wall and a cabinet). We cannot move this router as the cable provided is not long enough. In my view I feel it should have been placed on the first floor where there were less obstacles and the router could even distribute the WiFi.
  • The engineer did not test the WiFi signal around the house for any black spots and thus this issue wasn't found out until we manually had to update the devices.
  • Potential issues with the router/line?
All speed tests were carried out on https://samknows.com/realspeed/ at the time of this post.
I also have seen countless threads regarding compatibility issues between SkyQ and non Sky routers, so it looks like I'm in a world of hurt there.
To be honest, I'm not impressed by the drop in speeds of connectivity as I'm receiving nowhere near what was advertised - however this could just be teething issues. Should the speeds (especially across the 2.4ghz band) drop off that significantly so close to the hub 4 router?
Please let me know your thoughts and whether you require any further information.
EDIT: I think this should have been posted in the "Speed" forum. Please move if you feel its acceptable.
Tags (3)
  • 9
Message 2 of 17
Re: Gig1 Fibre - Slow Connectivity, SkyQ issues
3.0 Downstream channels
1 411000000 4.699997 38.983261 QAM256 1
2 419000000 5.199997 38.983261 QAM256 2
3 427000000 5.400002 40.366287 QAM256 3
4 435000000 4.900002 38.983261 QAM256 4
5 443000000 5.199997 38.983261 QAM256 5
6 451000000 5.800003 40.366287 QAM256 6
7 459000000 5.800003 38.983261 QAM256 7
8 467000000 5.400002 38.983261 QAM256 8
9 475000000 5.300003 38.983261 QAM256 9
10 483000000 5.900002 38.983261 QAM256 10
11 491000000 6.000000 40.366287 QAM256 11
12 499000000 5.800003 40.946209 QAM256 12
13 507000000 5.699997 40.366287 QAM256 13
14 515000000 6.000000 40.366287 QAM256 14
15 523000000 6.400002 40.366287 QAM256 15
16 531000000 6.199997 40.946209 QAM256 16
17 539000000 6.000000 40.366287 QAM256 17
18 547000000 5.900002 40.366287 QAM256 18
19 555000000 6.300003 40.366287 QAM256 19
20 563000000 6.300003 40.366287 QAM256 20
21 571000000 6.000000 40.946209 QAM256 21
22 579000000 5.900002 40.366287 QAM256 22
23 587000000 5.900002 38.983261 QAM256 23
24 595000000 6.000000 40.366287 QAM256 24
25 603000000 5.599998 38.983261 QAM256 25
26 611000000 5.199997 38.983261 QAM256 26
27 619000000 5.500000 38.983261 QAM256 27
28 627000000 5.900002 38.983261 QAM256 28
29 635000000 5.599998 38.983261 QAM256 29
30 643000000 5.099998 38.983261 QAM256 30
31 651000000 5.199997 38.605377 QAM256 31
1 Locked 0 0 0
2 Locked 256532414 1 0
3 Locked 578473207 0 0
4 Locked 246598035 0 0
5 Locked 256382257 0 0
6 Locked 255948656 0 0
7 Locked 246821750 0 0
8 Locked 258617643 0 0
9 Locked 270961819 0 0
10 Locked 270502927 0 0
11 Locked 260246076 0 0
12 Locked 252615406 0 0
13 Locked 272059870 1 0
14 Locked 272106894 0 0
15 Locked 261101184 0 0
16 Locked 229044157 0 0
17 Locked 237572910 2 0
18 Locked 237897758 1 0
19 Locked 229541298 0 0
20 Locked 229171580 0 0
21 Locked 238843206 0 0
22 Locked 238710479 0 0
23 Locked 230022100 0 0
24 Locked 304770751 0 0
25 Locked 316314421 0 0
26 Locked 316703759 1 0
27 Locked 304568178 1 0
28 Locked 304747750 2 0
29 Locked 317046157 0 0
30 Locked 318748133 2 0
31 Locked 1359645368 1 0
3.1 Downstream channels
159 96 4K 1880 QAM4096 728
159 Locked 6.0 154893660 0
  • 9
Message 3 of 17
3.0 Upstream channels
1 60300000 43.520599 5120 KSym/sec 64QAM 9
2 39400000 42.020599 5120 KSym/sec 8QAM 12
3 46200000 42.020599 5120 KSym/sec 64QAM 11
4 53700000 42.520599 5120 KSym/sec 64QAM 10
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 0 0
4 US_TYPE_STDMA 0 0 0 0
  • 9
Message 4 of 17
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
a69834ncxv9873254k;fg87dsfd;k
SFID
23308
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
23357
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
  • 9
Message 5 of 17
Thu 01/01/1970 00:01:21 4 Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:02:02 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 04/08/2020 21:44:22 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 04/08/2020 21:44:26 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 04/08/2020 22:01:59 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 4.53K
  • 266
  • 524
Message 6 of 17
Hello KCNoir
Welcome to our Forums and thanks for bringing this matter to our attention
Sorry though to hear you are having issue with the connection and wifi
There are 2 things I would like to suggest
Return visit of engineer to relocate hub to a more suitable place
Send out a pair of booster to help with the connection
There would be no charge for either
Let me know if you wish to go ahead with this
Gareth_L
  • 965
  • 55
  • 128
Superfast
Message 7 of 17
if would be helpful to know if your speeds are fine when using ethernet.
also, are you wifi devices capable of higher speeds?
2.4Ghz maxes out at 300Mbps
5Ghz "n" maxes out at 900Mbps
5Ghz "ac" has a range of 433 Mbps - 1.7 Gbps
of course ,those are maximum theortical speeds.
My Broadband Ping - spgray
  • 965
  • 55
  • 128
Superfast
Message 8 of 17
Range comparison – 2.4 GHz vs. 5 GHz
Standard Frequency Theoretical Distance Real World Distance
802.11a5Ghz390 ft195 ft
802.11b2.4Ghz460 ft230 ft
802.11g2.4Ghz125 ft62 ft
802.11n2.4Ghz820 ft410 ft
802.11n5Ghz460 ft230 ft
802.11ac5Ghzup to 820 ft (amplified)up to 410 ft (amplified)
Speed comparison – 2.4 GHz vs. 5 GHz
Standard Frequency Theoretical Speed Real-World Speed
802.11a5Ghz6-54 Mbps3 - 32 Mbps
802.11b2.4Ghz11 Mbps2-3 Mbps
802.11g2.4Ghz54 Mbps10 -29 Mbps
802.11n2.4Ghz300 Mpbs150 Mbps
802.11n5Ghz900 Mbps450Mbps
802.11ac5Ghz433 Mbps - 1.7 Gbps210 Mbps - 1 G
  • 9
Message 9 of 17
Hi Gareth, Spgray
Thanks for your comments.
We have had an engineer attend this morning to relocate the router. Unfortunately testing has shown that the speeds have not improved. At the time of writing, the speeds are as follows when standing directly next to the SH4 router:
Ethernet connection to a Gigabit Ethernet port
Energy Efficient Ethernet has been switched off in Device Manager. BIOS has no limit set on the port.
  • Download: 520 Mbps
  • Upload: 47.2 Mbps
  • Latency: 21 ms
  • Jitters: 3.4 ms
  • Packet loss: N/A
Wireless (5 Ghz)  tested on a S20 Ultra
  • Download: 326 Mbps
  • Upload: 45Mbps
  • Latency: 25.4 ms
  • Jitter: 2.88 ms
Wireless (2.4 Ghz) tested on a S20 Ultra
  • Download: 84.5 Mbps
  • Upload: 46.1 Mbps
  • Latency: 28.9 ms
  • Jitter: 5.52 ms
These speeds are approximately halved when stood approximately 10 ft away from the router. The engineer carried out similar tests and received similar results. We also ran a network diagnostics test which returned errors with "WiFi connections".
The engineer came to two conclusions:
  1. The router may be faulty and will need to be replaced. Apparently I need to arrange this?
  2. We require wireless boosters. Again this is something I need to arrange?
  • 6.1K
  • 311
  • 541
Message 10 of 17
Hi KCNoir
Thanks for coming back to us.
I'll PM you now to sort this
Kind regards,
John_GS
