Rex_B
  • 5
Message 1 of 5
Getting large packet loss and high ping HUB 3 [Posted BQM and Router status]
So I've been experiencing major packet loss and and high ping from my router ever since I came back from Uni in December.
I tried narrowing the problem down by:
-Using a 10m cat8 ethernet cable instead of a powerline
-Removing all devices from the router and only one device connected
-Resetting the router
-Ensured that all wires are connected properly
-Ensured the coaxial cable connected to the wall isn't damaged
-Cleaning the router
But nothing seem to help the problem. Before I call an engineer, I'd like to know if there are anything else I could do so at least we won't have to troubleshoot the problem and waste time.
Here is the link to my live graph from BQM
p.s. I am still getting fast download speed (129 -190Mbps) using Google's internet speed test so I have that going for me, which is nice.
Rex_B
  • 5
Message 2 of 5
Re: Getting large packet loss and high ping HUB 3 [Posted BQM and Router status]
Refresh data
1 330750000 10 40 256 qam 25
2 266750000 8.1 40 256 qam 17
3 274750000 8.5 40 256 qam 18
4 282750000 8.6 40 256 qam 19
5 290750000 9 40 256 qam 20
6 298750000 9 40 256 qam 21
7 306750000 9 40 256 qam 22
8 314750000 9.1 40 256 qam 23
9 322750000 9.6 40 256 qam 24
10 370750000 10.6 40 256 qam 26
11 378750000 11 40 256 qam 27
12 386750000 10.9 40 256 qam 28
13 394750000 11 40 256 qam 29
14 402750000 10.8 40 256 qam 30
15 410750000 10.9 40 256 qam 31
16 418750000 10.8 40 256 qam 32
17 426750000 11.3 40 256 qam 33
18 434750000 10.9 40 256 qam 34
19 442750000 11.4 40 256 qam 35
20 450750000 11.1 40 256 qam 36
21 458750000 11.5 40 256 qam 37
22 466750000 11 40 256 qam 38
23 474750000 11.3 40 256 qam 39
24 482750000 11 40 256 qam 40
Rex_B
  • 5
Message 3 of 5
15370000043.3512064 qam6
23940000041.8512064 qam8
34620000043.3512064 qam7
46030000044.8512064 qam5
Rex_B
  • 5
Message 4 of 5
12/02/2021 20:29:4 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/02/2021 20:29:4 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 13:27:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:03:36 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:36 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:29 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:23 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:23 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:01:22 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:7 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:4 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:3 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:1 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:00:1 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 23:59:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2021 18:56:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2021 13:59:48 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Rex_B
  • 5
Message 5 of 5
[Semi-Solved] Check your firewall settings
So I had another look at my hub settings (accessed by entering the IP address of you router, details can be found on your router) realised that not all of my firewall settings are checked. Specifically the "Block fragmented IP packets" option. After checking that, my performance has been. I still get packet loss and ping spikes but a lot more manageable.
