on 28-11-2023 22:14
I've had constant issues with the hub5 so i changed to the hub 4,even the technician visit I had yesterday said the hub 5 was rushed out to quick,when I set the hub4 up I ran the diagnostic tool in the hub ui setting and it said I had network issues,does my power levels seem OK,any issues stand out
on 01-12-2023 11:00
Hi hash70,
Thank you for your post. I'm very sorry to hear about the issue with your broadband service.
I have ran a check on our side and from what I can see it is showing everything is within spec.
How is the service today?
^Martin
on 01-12-2023 12:10
As per Martin the stats look good to me. I see that you are in modem mode using an Asus (?) router. Consider disabling QOS on that and ensuring its firmware is current.
