05-04-2022 12:13 - edited 05-04-2022 12:16
Everything was fine until yesterday when I randomly started getting to 200ms+ every 10-30seconds (over ethernet) for 1 second. I've tried troubleshooting (reset modem and router, replug cables, restart, try different cables, different devices) but its the same problem. Download speed is fine and it's not noticeable in video streaming platforms. I tried phoning up however they said everything was fine on their end and the steps they suggested I already tried. I have the 350mb package and no device is downloading when this is happening.
Ping test - 24 ms - 2022-04-05 13:14 - www.meter.net this is what it looks like
this is what the monitor looks like so far
on 05-04-2022 22:12
on 11-04-2022 13:05
Hi LiamVM1,
Thank you for your post and I am sorry you are having issues, you will need to take the hub out of modem mode and then run a packet loss test for an accurate reading, keep us posted on this.
I checked our systems and also your upstream and downstream levels and area latency all is fine.
Zoie
on 12-04-2022 14:30
The download/upload and average latency is fine, however in games and other applications, the ms jumps to 150-400 range. Everything was fine until a week ago I don't know what happened. I'll have to contact again today because its unplayable for over a week now. (there was maintenance from 12am to 8am early this morning but issue is still here)
on 14-04-2022 17:00
Hi LiamVM1 thanks for getting back to us.
I am sorry to hear that you're still have the issues. We've had another look and still cannot find anything that explains the issues you're having. Is it only online gaming that's being impacted and do you mean specific games or all games?
Lee_R
on 14-04-2022 18:03
on 14-04-2022 18:40
I've tried it, its the same result unfortunately, nothing seems to work troubleshooting wise.
on 14-04-2022 18:42
All online games and its noticeable in VOIP apps such as discord
on 14-04-2022 19:01
An engineer is arranged to come out on the 18th to see if there is a issue otherwise i'll be charged £25 but at this point i'm out of options than hopelessly waiting to play online games again.
on 14-04-2022 23:07
Update: Something has fixed the issue for now
